Ana içeriğe geç
Canon PowerShot G9 SD-Card Slot Write Lock.
Neye ihtiyacın var
  1. Canon PowerShot G9 SD-Card Slot Write Lock., Open rear cover of camera.: adım 1, 2 resimden 1. Canon PowerShot G9 SD-Card Slot Write Lock., Open rear cover of camera.: adım 1, 2 resimden 2.
    • Be very careful not to touch any charged flash capacitor
    • Remove screws as marked. 2 for strap holder, 5 for back cover
    • Remove Back cover and strap holder
  2. Canon PowerShot G9 SD-Card Slot Write Lock., Remove Buttons.: adım 2, 2 resimden 1. Canon PowerShot G9 SD-Card Slot Write Lock., Remove Buttons.: adım 2, 2 resimden 2.
    • Remove the two screws circled green.
    • Remove the buttons.
  3. Canon PowerShot G9 SD-Card Slot Write Lock., Remove Jog Dial Unit.: adım 3, 3 resimden 1. Canon PowerShot G9 SD-Card Slot Write Lock., Remove Jog Dial Unit.: adım 3, 3 resimden 2. Canon PowerShot G9 SD-Card Slot Write Lock., Remove Jog Dial Unit.: adım 3, 3 resimden 3.
    • Disconnect ribbon cable by lifting up flap.
    • Disconnect other cable (another flap)
    • Remove jog dial unit
  4. Canon PowerShot G9 SD-Card Slot Write Lock., Remove Finder dial.: adım 4, 2 resimden 1. Canon PowerShot G9 SD-Card Slot Write Lock., Remove Finder dial.: adım 4, 2 resimden 2.
    • Remove the one screw circled green.
    • Remove the finder dial
  5. Canon PowerShot G9 SD-Card Slot Write Lock., Remove LCD.: adım 5, 3 resimden 1. Canon PowerShot G9 SD-Card Slot Write Lock., Remove LCD.: adım 5, 3 resimden 2. Canon PowerShot G9 SD-Card Slot Write Lock., Remove LCD.: adım 5, 3 resimden 3.
    • Remove screw and lift LCD upwards very carefully. Do not put any strain on cables.
    • Carefully remove flex cables. The left has a flap that needs to be opened (up), the right just needs to be pulled out. Be careful when re-inserting the right one, you can easily damage the fragile cable.
    • Remove the LCD
  6. Canon PowerShot G9 SD-Card Slot Write Lock., Remove main PCB.: adım 6, 3 resimden 1. Canon PowerShot G9 SD-Card Slot Write Lock., Remove main PCB.: adım 6, 3 resimden 2. Canon PowerShot G9 SD-Card Slot Write Lock., Remove main PCB.: adım 6, 3 resimden 3.
    • Remove screws.
    • Disconnect connectors for Lens assembly
    • Carefully disconnect the tiny cable
    • Next step is removing the PCB. I made the mistake not to take care about the battery compartment switch. If you are not careful, the black lever will break off. Not a problem though, because then the camera will work also with opened battery compartmen
    • Remove main PCB by slightly bending outward the cover for the jack with fingernail. Now lift the PCB slightly upwards.
    • Look under the PCB, there is a connector that needs to be separated by means of a small screwdriver or spudger.
    • Re-attaching the connector is not easy. I used a small screwdriver to carefully press the connector back in place.
    • This is not the official method to do this. Normally the Top cover and several other parts need to be removed too.
  7. Canon PowerShot G9 SD-Card Slot Write Lock., Check SD-Card Slot.: adım 7, 2 resimden 1. Canon PowerShot G9 SD-Card Slot Write Lock., Check SD-Card Slot.: adım 7, 2 resimden 2.
    • Measure continuity with a multimeter on SD-card slot write protect switch.
    • If it is not working, short the two points with a bodge wire, so write lock is disabled
    • Another possible fault is a broken soldering joint holding the case of the SD-card reader in place.
Sonuç
Repeat the steps in order to reassemble your device.
Bir başkası bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
de en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Thomas Widmaier
2.039 İtibar
10 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.519 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 1,039
