Ana içeriğe geç
Canon PowerShot S100 Outer Case Replacement
Neye ihtiyacın var
  1. Canon PowerShot S100 Outer Case Replacement, Outer Case: adım 1, 3 resimden 1. Canon PowerShot S100 Outer Case Replacement, Outer Case: adım 1, 3 resimden 2. Canon PowerShot S100 Outer Case Replacement, Outer Case: adım 1, 3 resimden 3.
    • Remove the 2 screws (3.2mm, Phillips #00) found on the bottom side of the camera.
    • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera.
    • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera where the terminals are.
    • Open the flap revealing the cable inputs and remove the final screw (3.8mm, Phillips #00) found inside.
  2. Canon PowerShot S100 Outer Case Replacement: adım 2, 1 resimden 1.
    • Turn the camera so that the LCD screen is facing you.
    • Remove the back panel by pulling it off of the camera.
  3. Canon PowerShot S100 Outer Case Replacement: adım 3, 3 resimden 1. Canon PowerShot S100 Outer Case Replacement: adım 3, 3 resimden 2. Canon PowerShot S100 Outer Case Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Turn the camera so that the lens is facing you.
    • Do not pull the front panel off without removing the ribbon cable first.
    • Slowly lift the front panel from the camera.
    • The ribbon cable is connecting the front panel to the camera. Using the tweezers, gently pull the ribbon cable out of its socket.
    • A spudger may also be used to remove the ribbon cable.
    • Remove the rubber guard that rests on top of the lens.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ricky
968 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-4, Leahy Winter 2015 USF Tampa, Team 1-4, Leahy Winter 2015 üyesi
USFT-LEAHY-W15S1G4
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 1,218
