Ana içeriğe geç
Canon PowerShot S400 Shutter Button Assembly Replacement
Neye ihtiyacın var
  1. Canon PowerShot S400 Shutter Button Assembly Replacement, Shutter Button Assembly: adım 1, 2 resimden 1. Canon PowerShot S400 Shutter Button Assembly Replacement, Shutter Button Assembly: adım 1, 2 resimden 2.
    • Unless otherwise stated,a #00 philips screwdriver will be used to remove screws.
    • Remove the 4.75mm screw located in the top right corner of the backside of the camera.
    • Remove the four # screws located on the bottom of the camera.
  2. Canon PowerShot S400 Shutter Button Assembly Replacement: adım 2, 3 resimden 1. Canon PowerShot S400 Shutter Button Assembly Replacement: adım 2, 3 resimden 2. Canon PowerShot S400 Shutter Button Assembly Replacement: adım 2, 3 resimden 3.
    • Remove the two screws located on the right side of the camera.(the side with the USB adaption plug)
    • Remove the four screws on the left side of the camera.
    • This will release a small metal plate. Remove this plate.
  3. Canon PowerShot S400 Shutter Button Assembly Replacement: adım 3, 3 resimden 1. Canon PowerShot S400 Shutter Button Assembly Replacement: adım 3, 3 resimden 2. Canon PowerShot S400 Shutter Button Assembly Replacement: adım 3, 3 resimden 3.
    • There is a small black plastic piece that sits above the lens underneath the camera case. This plastic piece may fall out when you remove the cases; recover the piece and save it.
    • Now separate the front and back camera casings.
  4. Canon PowerShot S400 Shutter Button Assembly Replacement: adım 4, 1 resimden 1.
    • Using a spudger, carefully pry the shutter button assembly from the camera.
    • Install the replacement shutter button assembly.
Sonuç
Ross Bryan
359 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-19, Amido Winter 2011 Cal Poly, Team 5-19, Amido Winter 2011 üyesi
CPSU-AMIDO-W11S5G19
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 2,705
