Ana içeriğe geç
Canon PowerShot S410 Motherboard Battery Replacement
Neye ihtiyacın var
  1. Canon PowerShot S410 Motherboard Battery Replacement, Battery: adım 1, 2 resimden 1. Canon PowerShot S410 Motherboard Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the camera with the bottom side facing up.
    • Locate the panel labeled "Batt. Open"
    • Place your finger on the panel and slide it in the direction of the arrow.
    • The slot will swing open revealing the battery pack.
  2. Canon PowerShot S410 Motherboard Battery Replacement: adım 2, 1 resimden 1.
    • Pull the orange lever and the battery will spring out slightly.
  3. Canon PowerShot S410 Motherboard Battery Replacement: adım 3, 2 resimden 1. Canon PowerShot S410 Motherboard Battery Replacement: adım 3, 2 resimden 2.
    • Grasp the battery and fully pull it out of its slot.
    • When placing the new battery back in the slot, the arrow on the battery must align with the arrow on the camera.
  4. Canon PowerShot S410 Motherboard Battery Replacement, Back Cover: adım 4, 1 resimden 1.
    • Start by laying the camera flat with the LCD screen facing up.
    • Using the Phillips #0 screwdriver, remove the 3.8mm screw in the upper right corner.
  5. Canon PowerShot S410 Motherboard Battery Replacement: adım 5, 1 resimden 1.
    • Position the camera with the bottom facing up.
    • Twist the screwdriver counter-clockwise to remove the 4.8mm screw.
    • Repeat to remove the two 2.3mm screws.
  6. Canon PowerShot S410 Motherboard Battery Replacement: adım 6, 2 resimden 1. Canon PowerShot S410 Motherboard Battery Replacement: adım 6, 2 resimden 2.
    • Position the camera so that the rubber "AV Out Digital" tab is facing upward.
    • Slide the rubber tab to reveal the bottom screw.
    • Using the screwdriver, remove the two 3.7mm screws.
  7. Canon PowerShot S410 Motherboard Battery Replacement: adım 7, 1 resimden 1.
    • Turn the camera with the back side facing you.
    • Grip the edges of the back plate, and carefully slide it off.
    • If there is any resistance in movement, double check there are no screws left in the chassis.
  8. Canon PowerShot S410 Motherboard Battery Replacement, Front Cover: adım 8, 2 resimden 1. Canon PowerShot S410 Motherboard Battery Replacement, Front Cover: adım 8, 2 resimden 2.
    • Orient the camera as in the picture.
    • Remove the two 2.3mm outer screws using the Phillips #0 screwdriver.
    • Remove the two 3.8mm screws near the strap bracket.
    • Remove the small panel covering the mounting bracket.
    • Remove the door covering the memory card.
  9. Canon PowerShot S410 Motherboard Battery Replacement: adım 9, 1 resimden 1.
    • Rotate the camera so that the bottom side is facing you.
    • Remove the 3.8mm screw below the mounting bracket using the Phillips screwdriver.
  10. Canon PowerShot S410 Motherboard Battery Replacement: adım 10, 1 resimden 1.
    • Rotate the camera so that the front is facing you.
    • Grasp the sides of the front cover and carefully pull the front panel off of the camera.
  11. Canon PowerShot S410 Motherboard Battery Replacement, Motherboard Battery: adım 11, 1 resimden 1.
    • Position the camera so that the motherboard is facing you.
    • Remove the plastic flap covering the motherboard.
    • Place edge of iPod Opening Tool in the small opening between the battery and the motherboard.
    • Pry the battery off of the motherboard using the iPod Opening Tool.
Sonuç
Ryan Bolton
307 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 11-27, Maness Winter 2011 Cal Poly, Team 11-27, Maness Winter 2011 üyesi
CPSU-MANESS-W11S11G27
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 2,221
