Giriş
This guide will show you how to remove and replace the button panel on the top of the camera.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
Locate the panel labeled "Batt. Open"
Place your finger on the panel and slide it in the direction of the arrow.
The slot will swing open revealing the battery pack.
Remove the two 2.3mm outer screws.
Remove the two 3.8mm screws near the strap bracket.
Remove small panel covering mounting bracket.
Remove door covering memory card.
Using your fingernail, gently pry up the clip holding the button panel in place along the side of the camera.
Bir başkası bu kılavuzu tamamladı.
