Ana içeriğe geç
Canon PowerShot S500 Front and Rear Casing Replacement
Neye ihtiyacın var
  1. Canon PowerShot S500 Front and Rear Casing  Replacement, Front and Rear Casing : adım 1, 2 resimden 1. Canon PowerShot S500 Front and Rear Casing  Replacement, Front and Rear Casing : adım 1, 2 resimden 2.
    • Unscrew five Phillips screws using a #0 Phillips screwdriver.
    • One screw is on upper right corner of the back panel.
    • The other four screws are on the bottom of the camera.
  2. Canon PowerShot S500 Front and Rear Casing  Replacement: adım 2, 1 resimden 1.
    • Open the memory card cover by moving the slide switch toward the top end of of the camera.
    • Remove the memory card from the slot.
  3. Canon PowerShot S500 Front and Rear Casing  Replacement: adım 3, 1 resimden 1.
    • Remove the rear cover from the rest of the camera.
    • This may require gentle rocking of the case to free it.
  4. Canon PowerShot S500 Front and Rear Casing  Replacement: adım 4, 2 resimden 1. Canon PowerShot S500 Front and Rear Casing  Replacement: adım 4, 2 resimden 2.
    • Unscrew the four Phillips screws from the side of the casing and one screw from the bottom using a #0 Phillips screwdriver.
  5. Canon PowerShot S500 Front and Rear Casing  Replacement: adım 5, 1 resimden 1.
    • Free the front cover from the rest of the camera.
    • The cover may require gentle rocking to remove.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Nathan Balcom
102 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 16-28, Maness Winter 2010 Cal Poly, Team 16-28, Maness Winter 2010 üyesi
CPSU-MANESS-W10S16G28
4 Üyeler
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 20
Her zaman: 1,663
