Ana içeriğe geç
Canon PowerShot S80 Flash Replacement
Neye ihtiyacın var
  1. Canon PowerShot S80 Flash Replacement, Outer Casing: adım 1, 2 resimden 1. Canon PowerShot S80 Flash Replacement, Outer Casing: adım 1, 2 resimden 2.
    • Remove the knot on the wrist lanyard.
    • Remove the battery and the memory card.
  2. Canon PowerShot S80 Flash Replacement: adım 2, 2 resimden 1. Canon PowerShot S80 Flash Replacement: adım 2, 2 resimden 2.
    • Begin removing the screws on the bottom of the outer casing.
    • Next, remove the rest of the screws from the outer casing.
  3. Canon PowerShot S80 Flash Replacement: adım 3, 3 resimden 1. Canon PowerShot S80 Flash Replacement: adım 3, 3 resimden 2. Canon PowerShot S80 Flash Replacement: adım 3, 3 resimden 3.
    • Gently pull the front cover off of the camera.
  4. Canon PowerShot S80 Flash Replacement: adım 4, 3 resimden 1. Canon PowerShot S80 Flash Replacement: adım 4, 3 resimden 2. Canon PowerShot S80 Flash Replacement: adım 4, 3 resimden 3.
    • Open the "A/V Out Digital" cover. Remove the screw inside.
    • Gently pull off the back casing.
    • Remove the black "L" shaped piece of metal.
  5. Canon PowerShot S80 Flash Replacement, LCD Screen: adım 5, 1 resimden 1.
    • Remove the three screws that are holding the screen in place. Free the screen from the underlying components.
    • Be careful with the ribbon wire that is still attached on the left side of the screen.
  6. Canon PowerShot S80 Flash Replacement: adım 6, 2 resimden 1. Canon PowerShot S80 Flash Replacement: adım 6, 2 resimden 2.
    • With the spudger, gently lift the black flap that is holding the wide ribbon cable wire in place.
    • Unplug the wide ribbon cable.
    • Unplug the narrow ribbon cable to free the LCD screen from the camera body.
  7. Canon PowerShot S80 Flash Replacement, Flash: adım 7, 1 resimden 1.
    • Remove the L-shaped corner trim containing the picture button.
    • Carefully unplug the connection cable that is attached.
  8. Canon PowerShot S80 Flash Replacement: adım 8, 2 resimden 1. Canon PowerShot S80 Flash Replacement: adım 8, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Pull the selector wheel from the top corner of the camera.
    • Carefully remove the ribbon cable connection with a set of tweezers.
  9. Canon PowerShot S80 Flash Replacement: adım 9, 1 resimden 1.
    • With a Phillips #00 Screwdriver, unscrew the zoom toggle switch and remove it from the camera.
  10. Canon PowerShot S80 Flash Replacement: adım 10, 1 resimden 1.
    • With a Phillips #00 Screwdriver, unscrew the flash board.
  11. Canon PowerShot S80 Flash Replacement: adım 11, 1 resimden 1.
    • Remove the cable connection. With a metal spudger, gently pry up.
    • Remove the ribon cable. With a metal spudger, gently lift up the black tab.
  12. Canon PowerShot S80 Flash Replacement: adım 12, 1 resimden 1.
    • Lift the flash bulb unit upwards from the camera.
  13. Canon PowerShot S80 Flash Replacement: adım 13, 2 resimden 1. Canon PowerShot S80 Flash Replacement: adım 13, 2 resimden 2.
    • Lift the entire three-part flash assembly from the camera.
Sonuç
BrettH
219 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 19-5, Maness SU 2012 Cal Poly, Team 19-5, Maness SU 2012 üyesi
CPSU-MANESS-SU12S19G5
1 Üye
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 3,685
