Ana içeriğe geç
Canon PowerShot S80 Motherboard Replacement
Neye ihtiyacın var
  1. Canon PowerShot S80 Motherboard Replacement, Outer Casing: adım 1, 2 resimden 1. Canon PowerShot S80 Motherboard Replacement, Outer Casing: adım 1, 2 resimden 2.
    • Remove the knot on the wrist lanyard.
    • Remove the battery and the memory card.
  2. Canon PowerShot S80 Motherboard Replacement: adım 2, 2 resimden 1. Canon PowerShot S80 Motherboard Replacement: adım 2, 2 resimden 2.
    • Begin removing the screws on the bottom of the outer casing.
    • Next, remove the rest of the screws from the outer casing.
  3. Canon PowerShot S80 Motherboard Replacement: adım 3, 3 resimden 1. Canon PowerShot S80 Motherboard Replacement: adım 3, 3 resimden 2. Canon PowerShot S80 Motherboard Replacement: adım 3, 3 resimden 3.
    • Gently pull the front cover off of the camera.
  4. Canon PowerShot S80 Motherboard Replacement: adım 4, 3 resimden 1. Canon PowerShot S80 Motherboard Replacement: adım 4, 3 resimden 2. Canon PowerShot S80 Motherboard Replacement: adım 4, 3 resimden 3.
    • Open the "A/V Out Digital" cover. Remove the screw inside.
    • Gently pull off the back casing.
    • Remove the black "L" shaped piece of metal.
  5. Canon PowerShot S80 Motherboard Replacement, LCD Screen: adım 5, 1 resimden 1.
    • Remove the three screws that are holding the screen in place. Free the screen from the underlying components.
    • Be careful with the ribbon wire that is still attached on the left side of the screen.
  6. Canon PowerShot S80 Motherboard Replacement: adım 6, 2 resimden 1. Canon PowerShot S80 Motherboard Replacement: adım 6, 2 resimden 2.
    • With the spudger, gently lift the black flap that is holding the wide ribbon cable wire in place.
    • Unplug the wide ribbon cable.
    • Unplug the narrow ribbon cable to free the LCD screen from the camera body.
  7. Canon PowerShot S80 Motherboard Replacement, Motherboard: adım 7, 1 resimden 1.
    • Remove the screws holding down the function set button.
  8. Canon PowerShot S80 Motherboard Replacement: adım 8, 1 resimden 1.
    • Gently pry up the tab with a metal spudger and remove the ribbon cable.
  9. Canon PowerShot S80 Motherboard Replacement: adım 9, 1 resimden 1.
    • Be mindful of the pins as you lift up and remove the function/set button.
  10. Canon PowerShot S80 Motherboard Replacement: adım 10, 3 resimden 1. Canon PowerShot S80 Motherboard Replacement: adım 10, 3 resimden 2. Canon PowerShot S80 Motherboard Replacement: adım 10, 3 resimden 3.
    • Remove the screws from the metal plate.
    • Gently remove the metal plate.
  11. Canon PowerShot S80 Motherboard Replacement: adım 11, 2 resimden 1. Canon PowerShot S80 Motherboard Replacement: adım 11, 2 resimden 2.
    • Lift the tab connecting the ribbon cable and detach.
  12. Canon PowerShot S80 Motherboard Replacement: adım 12, 2 resimden 1. Canon PowerShot S80 Motherboard Replacement: adım 12, 2 resimden 2.
    • Use a spudger to lift up the ribbon cable tab.
    • Detach the ribbon cable.
  13. Canon PowerShot S80 Motherboard Replacement: adım 13, 2 resimden 1. Canon PowerShot S80 Motherboard Replacement: adım 13, 2 resimden 2.
    • Gently remove the entire ribbon cable connection to release the ribbon cable from the camera.
  14. Canon PowerShot S80 Motherboard Replacement: adım 14, 1 resimden 1.
    • Unscrew the circuit board from the flash unit.
  15. Canon PowerShot S80 Motherboard Replacement: adım 15, 3 resimden 1. Canon PowerShot S80 Motherboard Replacement: adım 15, 3 resimden 2. Canon PowerShot S80 Motherboard Replacement: adım 15, 3 resimden 3.
    • Pry up the ribbon cable connection and remove it from the camera.
    • Lift the ribbon cable tab and completely detach the cable from the camera.
  16. Canon PowerShot S80 Motherboard Replacement: adım 16, 1 resimden 1.
    • Pry up the connection, being mindful of the light adhesive.
  17. Canon PowerShot S80 Motherboard Replacement: adım 17, 1 resimden 1.
    • Remove the last screw holding the motherboard to the main body.
  18. Canon PowerShot S80 Motherboard Replacement: adım 18, 2 resimden 1. Canon PowerShot S80 Motherboard Replacement: adım 18, 2 resimden 2.
    • Use a spudger to gently lift the motherboard from the camera.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
BrettH
219 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 19-5, Maness SU 2012 Cal Poly, Team 19-5, Maness SU 2012 üyesi
CPSU-MANESS-SU12S19G5
1 Üye
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 9
Son 30 gün: 21
Her zaman: 4,519
