Ana içeriğe geç
Canon PowerShot S80 Speaker Replacement
Neye ihtiyacın var
  1. Canon PowerShot S80 Speaker Replacement, Outer Casing: adım 1, 2 resimden 1. Canon PowerShot S80 Speaker Replacement, Outer Casing: adım 1, 2 resimden 2.
    • Remove the knot on the wrist lanyard.
    • Remove the battery and the memory card.
  2. Canon PowerShot S80 Speaker Replacement: adım 2, 2 resimden 1. Canon PowerShot S80 Speaker Replacement: adım 2, 2 resimden 2.
    • Begin removing the screws on the bottom of the outer casing.
    • Next, remove the rest of the screws from the outer casing.
  3. Canon PowerShot S80 Speaker Replacement: adım 3, 3 resimden 1. Canon PowerShot S80 Speaker Replacement: adım 3, 3 resimden 2. Canon PowerShot S80 Speaker Replacement: adım 3, 3 resimden 3.
    • Gently pull the front cover off of the camera.
  4. Canon PowerShot S80 Speaker Replacement: adım 4, 3 resimden 1. Canon PowerShot S80 Speaker Replacement: adım 4, 3 resimden 2. Canon PowerShot S80 Speaker Replacement: adım 4, 3 resimden 3.
    • Open the "A/V Out Digital" cover. Remove the screw inside.
    • Gently pull off the back casing.
    • Remove the black "L" shaped piece of metal.
  5. Canon PowerShot S80 Speaker Replacement, Speaker: adım 5, 1 resimden 1.
    • Remove the screw and unplug the wire lead.
    • Gently remove the speaker from the camera body.
Sonuç
BrettH
219 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 19-5, Maness SU 2012 Cal Poly, Team 19-5, Maness SU 2012 üyesi
CPSU-MANESS-SU12S19G5
1 Üye
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 14
Her zaman: 2,043
