Ana içeriğe geç
Canon PowerShot SD1000 Flash Unit Replacement
Neye ihtiyacın var
  1. Canon PowerShot SD1000 Flash Unit Replacement, Back Panel: adım 1, 2 resimden 1. Canon PowerShot SD1000 Flash Unit Replacement, Back Panel: adım 1, 2 resimden 2.
    • Remove the two 2.9 mm screws from the side panel closest to the camera lens.
  2. Canon PowerShot SD1000 Flash Unit Replacement: adım 2, 1 resimden 1.
    • Remove the two 2.9 mm screws from the camera bottom panel.
  3. Canon PowerShot SD1000 Flash Unit Replacement: adım 3, 1 resimden 1.
    • Remove the two 2.9 mm screws from the side panel farthest from the lens.
  4. Canon PowerShot SD1000 Flash Unit Replacement: adım 4, 1 resimden 1.
    • Pull the back panel away from the camera body, starting at the end with the function buttons.
  5. Canon PowerShot SD1000 Flash Unit Replacement: adım 5, 1 resimden 1.
    • Remove the small cover panel and the attached wrist strap mount.
  6. Canon PowerShot SD1000 Flash Unit Replacement, Front Case: adım 6, 1 resimden 1.
    • Remove the front cover by gently pulling it away from the camera body.
  7. Canon PowerShot SD1000 Flash Unit Replacement: adım 7, 1 resimden 1.
    • Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
  8. Canon PowerShot SD1000 Flash Unit Replacement, LCD Screen: adım 8, 1 resimden 1.
    • Remove the two 2.4 mm screws located at the top of the LCD panel.
  9. Canon PowerShot SD1000 Flash Unit Replacement: adım 9, 2 resimden 1. Canon PowerShot SD1000 Flash Unit Replacement: adım 9, 2 resimden 2.
    • Pull up the metal frame surrounding the LCD screen starting at the side of the camera.
  10. Canon PowerShot SD1000 Flash Unit Replacement: adım 10, 1 resimden 1.
    • Push the metal frame away from the metal tab using the spudger to detach the frame.
    • Rotate the metal frame upwards.
    • The metal framing should be attached by a metal tab towards the bottom of the camera, near the function buttons.
  11. Canon PowerShot SD1000 Flash Unit Replacement: adım 11, 2 resimden 1. Canon PowerShot SD1000 Flash Unit Replacement: adım 11, 2 resimden 2.
    • Carefully lift the metal frame from the camera.
    • Remove the black LCD screen, leaving the thin lens pieces in place.
    • BE CAREFUL; both components are attached by an orange connector ribbon and cannot be removed yet.
  12. Canon PowerShot SD1000 Flash Unit Replacement: adım 12, 3 resimden 1. Canon PowerShot SD1000 Flash Unit Replacement: adım 12, 3 resimden 2. Canon PowerShot SD1000 Flash Unit Replacement: adım 12, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Carefully pull on the orange connector ribbon to disconnect the LCD screen.
    • The LCD screen can be pulled out of the frame before disconnecting its connector ribbon.
    • Tweezers are helpful to disconnect the ribbon.
  13. Canon PowerShot SD1000 Flash Unit Replacement, Flash Unit: adım 13, 2 resimden 1. Canon PowerShot SD1000 Flash Unit Replacement, Flash Unit: adım 13, 2 resimden 2.
    • Slide the metal frame off of the camera on the side that is closest to the flash mechanism.
  14. Canon PowerShot SD1000 Flash Unit Replacement: adım 14, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the 2.4 mm screw that secures the flash assembly.
  15. Canon PowerShot SD1000 Flash Unit Replacement: adım 15, 1 resimden 1.
    • Use the spudger to gently and carefully disconnect the flash assembly ribbon from the black connector lock.
  16. Canon PowerShot SD1000 Flash Unit Replacement: adım 16, 2 resimden 1. Canon PowerShot SD1000 Flash Unit Replacement: adım 16, 2 resimden 2.
    • Pull the flash assembly forward out of the camera to remove it.
    • BE CAREFUL when handling the flash assembly. Touching the capacitor (the black cylinder attached to the flash assembly) could shock you.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Phillip Phung
651 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-18, Maness Winter 2012 Cal Poly, Team 8-18, Maness Winter 2012 üyesi
CPSU-MANESS-W12S8G18
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 43
Her zaman: 3,238
