Ana içeriğe geç
Canon PowerShot SD1000 Front Case Replacement
Neye ihtiyacın var
  1. Canon PowerShot SD1000 Front Case Replacement, Back Panel: adım 1, 2 resimden 1. Canon PowerShot SD1000 Front Case Replacement, Back Panel: adım 1, 2 resimden 2.
    • Remove the two 2.9 mm screws from the side panel closest to the camera lens.
  2. Canon PowerShot SD1000 Front Case Replacement: adım 2, 1 resimden 1.
    • Remove the two 2.9 mm screws from the camera bottom panel.
  3. Canon PowerShot SD1000 Front Case Replacement: adım 3, 1 resimden 1.
    • Remove the two 2.9 mm screws from the side panel farthest from the lens.
  4. Canon PowerShot SD1000 Front Case Replacement: adım 4, 1 resimden 1.
    • Pull the back panel away from the camera body, starting at the end with the function buttons.
  5. Canon PowerShot SD1000 Front Case Replacement: adım 5, 1 resimden 1.
    • Remove the small cover panel and the attached wrist strap mount.
  6. Canon PowerShot SD1000 Front Case Replacement, Front Case: adım 6, 1 resimden 1.
    • Remove the front cover by gently pulling it away from the camera body.
  7. Canon PowerShot SD1000 Front Case Replacement: adım 7, 1 resimden 1.
    • Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
Sonuç
Phillip Phung
651 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-18, Maness Winter 2012 Cal Poly, Team 8-18, Maness Winter 2012 üyesi
CPSU-MANESS-W12S8G18
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 21
Her zaman: 1,519
