Parçalar
Hiçbir parçaya gerek yok.
  1. Remove the two screws from the side panel closest to the camera lens. Note: These screws are 2.9 mm long.
    • Remove the two screws from the side panel closest to the camera lens.
    • Note: These screws are 2.9 mm long.
  2. Remove the two screws from the camera bottom panel.
    • Remove the two screws from the camera bottom panel.
  3. Remove the 2 screws from the side panel farthest from the lens.
    • Remove the 2 screws from the side panel farthest from the lens.
  4. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  5. Pull the back panel away from the camera body, starting at the end with the function buttons.
    • Pull the back panel away from the camera body, starting at the end with the function buttons.
  6. Remove the small cover panel and attached wrist strap mount.
    • Remove the small cover panel and attached wrist strap mount.
  7. Remove the front cover by gently pulling it away from the camera body.
    • Remove the front cover by gently pulling it away from the camera body.
  8. Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
    • Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
Sonuç
Phillip Phung
486 İtibar
9 adet Kılavuz yazıldı
Takım
Cal Poly, Team 8-18, Maness Winter 2012 Cal Poly, Team 8-18, Maness Winter 2012 üyesi
CPSU-MANESS-W12S8G18
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 2
Her zaman: 1,024
