Ana içeriğe geç
Canon PowerShot SD1100 IS Function Buttons Replacement
Neye ihtiyacın var
  1. Canon PowerShot SD1100 IS Function Buttons Replacement, Front and Rear Cover: adım 1, 2 resimden 1. Canon PowerShot SD1100 IS Function Buttons Replacement, Front and Rear Cover: adım 1, 2 resimden 2.
    • Remove wrist strap and battery.
  2. Canon PowerShot SD1100 IS Function Buttons Replacement: adım 2, 3 resimden 1. Canon PowerShot SD1100 IS Function Buttons Replacement: adım 2, 3 resimden 2. Canon PowerShot SD1100 IS Function Buttons Replacement: adım 2, 3 resimden 3.
    • Remove 2 screws from each side of the camera (4 total, 0.102 in).
    • Remove 2 screws from the bottom on the camera (0.138 in).
    • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
  3. Canon PowerShot SD1100 IS Function Buttons Replacement: adım 3, 3 resimden 1. Canon PowerShot SD1100 IS Function Buttons Replacement: adım 3, 3 resimden 2. Canon PowerShot SD1100 IS Function Buttons Replacement: adım 3, 3 resimden 3.
    • Gently pull off the front cover.
    • The plate on the side should come off.
    • Gently pull off the back cover.
  4. Canon PowerShot SD1100 IS Function Buttons Replacement: adım 4, 1 resimden 1.
    • The cases should now be removed.
  5. Canon PowerShot SD1100 IS Function Buttons Replacement, Top Button Assembly: adım 5, 1 resimden 1.
    • Use the spudger to disconnect the black tab.
  6. Canon PowerShot SD1100 IS Function Buttons Replacement: adım 6, 1 resimden 1.
    • Gently pull off the shutter button assembly.
  7. Canon PowerShot SD1100 IS Function Buttons Replacement: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Use the tweezers to disconnect the microphone cable.
  8. Canon PowerShot SD1100 IS Function Buttons Replacement: adım 8, 1 resimden 1.
    • The shutter button assembly should now be removed.
  9. Canon PowerShot SD1100 IS Function Buttons Replacement, Function Buttons: adım 9, 1 resimden 1.
    • With the spudger, flip up the black tab on the main ribbon.
  10. Canon PowerShot SD1100 IS Function Buttons Replacement: adım 10, 2 resimden 1. Canon PowerShot SD1100 IS Function Buttons Replacement: adım 10, 2 resimden 2.
    • Gently pull straight out on the ribbon to disconnect it from the logic board.
  11. Canon PowerShot SD1100 IS Function Buttons Replacement: adım 11, 1 resimden 1.
    • By hand, gently unfold the function button board and lift it off the frame.
  12. Canon PowerShot SD1100 IS Function Buttons Replacement: adım 12, 1 resimden 1.
    • Congratulations! The function button board can now be replaced.
Sonuç
Wyatt Chan
235 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-32, Regan Winter 2011 Cal Poly, Team 3-32, Regan Winter 2011 üyesi
CPSU-REGAN-W11S3G32
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 1,978
