Ana içeriğe geç
Canon PowerShot SD1100 IS Top Button Assembly Replacement
Neye ihtiyacın var
  1. Canon PowerShot SD1100 IS Top Button Assembly Replacement, Front and Rear Cover: adım 1, 2 resimden 1. Canon PowerShot SD1100 IS Top Button Assembly Replacement, Front and Rear Cover: adım 1, 2 resimden 2.
    • Remove wrist strap and battery.
  2. Canon PowerShot SD1100 IS Top Button Assembly Replacement: adım 2, 3 resimden 1. Canon PowerShot SD1100 IS Top Button Assembly Replacement: adım 2, 3 resimden 2. Canon PowerShot SD1100 IS Top Button Assembly Replacement: adım 2, 3 resimden 3.
    • Remove 2 screws from each side of the camera (4 total, 0.102 in).
    • Remove 2 screws from the bottom on the camera (0.138 in).
    • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
  3. Canon PowerShot SD1100 IS Top Button Assembly Replacement: adım 3, 3 resimden 1. Canon PowerShot SD1100 IS Top Button Assembly Replacement: adım 3, 3 resimden 2. Canon PowerShot SD1100 IS Top Button Assembly Replacement: adım 3, 3 resimden 3.
    • Gently pull off the front cover.
    • The plate on the side should come off.
    • Gently pull off the back cover.
  4. Canon PowerShot SD1100 IS Top Button Assembly Replacement: adım 4, 1 resimden 1.
    • The cases should now be removed.
  5. Canon PowerShot SD1100 IS Top Button Assembly Replacement, Top Button Assembly: adım 5, 1 resimden 1.
    • Use the spudger to disconnect the black tab.
  6. Canon PowerShot SD1100 IS Top Button Assembly Replacement: adım 6, 1 resimden 1.
    • Gently pull off the shutter button assembly.
  7. Canon PowerShot SD1100 IS Top Button Assembly Replacement: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use the tweezers to disconnect the microphone cable.
  8. Canon PowerShot SD1100 IS Top Button Assembly Replacement: adım 8, 1 resimden 1.
    • The shutter button assembly should now be removed.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Wyatt Chan
235 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-32, Regan Winter 2011 Cal Poly, Team 3-32, Regan Winter 2011 üyesi
CPSU-REGAN-W11S3G32
3 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 14
Her zaman: 2,180
