Ana içeriğe geç
Canon PowerShot SD1200 IS Front and Rear Covers Replacement
Neye ihtiyacın var
  1. Canon PowerShot SD1200 IS Front and Rear Covers Replacement, Front and Rear Covers: adım 1, 1 resimden 1.
    • Remove the battery.
  2. Canon PowerShot SD1200 IS Front and Rear Covers Replacement: adım 2, 3 resimden 1. Canon PowerShot SD1200 IS Front and Rear Covers Replacement: adım 2, 3 resimden 2. Canon PowerShot SD1200 IS Front and Rear Covers Replacement: adım 2, 3 resimden 3.
    • Remove the two screws from the side of the camera casing with the strap. (4mm Phillips 00)
    • Remove the two screws from the bottom of the camera. (4mm Phillips 00)
    • Remove the two screws from the right side of the camera opposite the strap. (2mm Phillips 00)
  3. Canon PowerShot SD1200 IS Front and Rear Covers Replacement: adım 3, 2 resimden 1. Canon PowerShot SD1200 IS Front and Rear Covers Replacement: adım 3, 2 resimden 2.
    • Pull off the front cover.
    • If the top of the cover sticks, use gentle downward pressure on the retention clips above the lens to release.
    • Remove the back cover.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jeff Casper
860 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-5, Blackwell Fall 2016 USF Tampa, Team 17-5, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S17G5
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 28
Her zaman: 1,074
