Ana içeriğe geç
Canon PowerShot SD1200 IS Function Button Board Replacement
Neye ihtiyacın var
  1. Canon PowerShot SD1200 IS Function Button Board Replacement, Front and Rear Covers: adım 1, 1 resimden 1.
    • Remove the battery.
  2. Canon PowerShot SD1200 IS Function Button Board Replacement: adım 2, 3 resimden 1. Canon PowerShot SD1200 IS Function Button Board Replacement: adım 2, 3 resimden 2. Canon PowerShot SD1200 IS Function Button Board Replacement: adım 2, 3 resimden 3.
    • Remove the two screws from the side of the camera casing with the strap. (4mm Phillips 00)
    • Remove the two screws from the bottom of the camera. (4mm Phillips 00)
    • Remove the two screws from the right side of the camera opposite the strap. (2mm Phillips 00)
  3. Canon PowerShot SD1200 IS Function Button Board Replacement: adım 3, 2 resimden 1. Canon PowerShot SD1200 IS Function Button Board Replacement: adım 3, 2 resimden 2.
    • Pull off the front cover.
    • If the top of the cover sticks, use gentle downward pressure on the retention clips above the lens to release.
    • Remove the back cover.
  4. Canon PowerShot SD1200 IS Function Button Board Replacement, Function Buttons: adım 4, 1 resimden 1.
    • Use the spudger to lift the tab on the Zero Insertion Force (ZIF) connector located at the top of the function button board.
    • Be sure you are prying up on the hinged retaining flap, not the connector itself.
    • Slide out the ribbon cable from the connector.
  5. Canon PowerShot SD1200 IS Function Button Board Replacement: adım 5, 1 resimden 1.
    • Remove the top screw from the function button board. (3.5mm Phillips 00)
    • Remove the bottom screw from the function button board. (2.5mm Phillips 00)
  6. Canon PowerShot SD1200 IS Function Button Board Replacement: adım 6, 1 resimden 1.
    • Lift out the function button board.
Sonuç
Jeff Casper
860 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-5, Blackwell Fall 2016 USF Tampa, Team 17-5, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S17G5
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 311
