Giriş
Removing the LCD screen seems intimidating, but everything comes apart rather easily. You just have to lift tabs, remove a single screw and lift out the screen.
Neye ihtiyacın var
Bu adımda kullanılan alet:Tweezers$4.99
Use the spudger to lift the retaining flap on the Zero Insertion Force (ZIF) tab securing the thick ribbon cable.
Slide out the ribbon cable using fingers or tweezers.
Using tweezers, disconnect the small ribbon cable below the flash assembly from the No Fuss Connector by simply pulling the ribbon cable straight out.
2 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Hello do you guys sello the LCD screen and do you ship to México.
