Ana içeriğe geç
Canon PowerShot SD1300 IS Flash Assembly Replacement
Neye ihtiyacın var
  1. Canon PowerShot SD1300 IS Flash Assembly Replacement, Flash Assembly: adım 1, 3 resimden 1. Canon PowerShot SD1300 IS Flash Assembly Replacement, Flash Assembly: adım 1, 3 resimden 2. Canon PowerShot SD1300 IS Flash Assembly Replacement, Flash Assembly: adım 1, 3 resimden 3.
    • Remove the two 2mm J00 screws on the right exterior.
    • Remove a single 4 mm J00 on the bottom exterior.
    • Remove a single 3mm J00 on the left exterior.
  2. Canon PowerShot SD1300 IS Flash Assembly Replacement: adım 2, 1 resimden 1.
    • Once the front shell of the camera is removed the back shell should slide off just the same.
  3. Canon PowerShot SD1300 IS Flash Assembly Replacement: adım 3, 1 resimden 1.
    • Remove a 3mm J00 screw from behind wires under the flash.
  4. Canon PowerShot SD1300 IS Flash Assembly Replacement: adım 4, 1 resimden 1.
    • Use plastic opening tool to remove the screen to gain access to the screws to remove the Flash Assembly.
  5. Canon PowerShot SD1300 IS Flash Assembly Replacement: adım 5, 1 resimden 1.
    • Remove the two 3mm J00 screws under the screen.
    • Remove the 4mm J00 screws under the screen.
    • The flash assembly is now released and should be able to be removed from the front side of the camera.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Clayton
560 İtibar
5 adet Kılavuz yazıldı
Ekip
Texas Tech, Team S13-G1, Bennett Spring 2017 Texas Tech, Team S13-G1, Bennett Spring 2017 üyesi
TTU-BENNETT-S17S13G1
5 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 20
Her zaman: 360
