Ana içeriğe geç
Canon PowerShot SD1300 IS Lens Replacement
Neye ihtiyacın var
  1. Canon PowerShot SD1300 IS Lens Replacement, Lens: adım 1, 3 resimden 1. Canon PowerShot SD1300 IS Lens Replacement, Lens: adım 1, 3 resimden 2. Canon PowerShot SD1300 IS Lens Replacement, Lens: adım 1, 3 resimden 3.
    • Remove the two 2mm J00 screws on the right exterior.
    • Remove a single 4 mm J00 on the bottom exterior.
    • Remove a single 3mm J00 on the left exterior.
    • Remove a single 2mm J00 screw on the left exterior hidden under the A/V Out port.
  2. Canon PowerShot SD1300 IS Lens Replacement: adım 2, 1 resimden 1.
    • Once the front shell of the camera is removed the back shell should slide off just the same.
  3. Canon PowerShot SD1300 IS Lens Replacement: adım 3, 1 resimden 1.
    • Use one of your plastic opening tools to separate the screen from the main body of your PowerShot.
  4. Canon PowerShot SD1300 IS Lens Replacement: adım 4, 1 resimden 1.
    • Remove five of the 3mm J00 screws under the screen to release the lens for replacement.
    • Lens assembly should be removed through the front of the camera once screws are removed.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Clayton
560 İtibar
5 adet Kılavuz yazıldı
Ekip
Texas Tech, Team S13-G1, Bennett Spring 2017 Texas Tech, Team S13-G1, Bennett Spring 2017 üyesi
TTU-BENNETT-S17S13G1
5 Üyeler
1Rehber Yorum
I have a SD1300 IS and it has another case screw beneath a plastic cover just below the USB port.
Also step 4 shows 2 screws to remove on the lens that do not go through the metal frame. These should not be removed for lens removal.
It is necessary on mine to remove the 2 screws on the left side of the metal frame that attach to the lens assy.
Greg Reinhart - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 14
Son 30 gün: 49
Her zaman: 1,582
