Ana içeriğe geç
Canon PowerShot SD1400 IS User Interface Panel Replacement
Neye ihtiyacın var
  1. Canon PowerShot SD1400 IS User Interface Panel Replacement, User Interface Panel: adım 1, 3 resimden 1. Canon PowerShot SD1400 IS User Interface Panel Replacement, User Interface Panel: adım 1, 3 resimden 2. Canon PowerShot SD1400 IS User Interface Panel Replacement, User Interface Panel: adım 1, 3 resimden 3.
    • Remove the four 2.0 mm Phillips screws of the camera using the J00 bit from the 54-bit Driver Kit. There are two screws on both sides.
  2. Canon PowerShot SD1400 IS User Interface Panel Replacement: adım 2, 1 resimden 1.
    • Remove the 4.0 mm Phillips screw located on the bottom of the camera.
  3. Canon PowerShot SD1400 IS User Interface Panel Replacement: adım 3, 1 resimden 1.
    • Remove the front face panel of the camera by hand using firm pressure.
    • If one point of the face is stuck to the body, check if there is a screw preventing the front face from coming off.
  4. Canon PowerShot SD1400 IS User Interface Panel Replacement: adım 4, 1 resimden 1.
    • Remove the rear panel of the camera by hand using firm pressure.
  5. Canon PowerShot SD1400 IS User Interface Panel Replacement: adım 5, 1 resimden 1.
    • Remove the user interface panel by hand. The panel may fall out on its own, this is normal.
    • Replace the user interface panel by setting it in position.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Braxton Beal
702 İtibar
3 adet Kılavuz yazıldı
Ekip
Baylor, Team S1-G3, Johnson Spring 2018 Baylor, Team S1-G3, Johnson Spring 2018 üyesi
BU-JOHNSON-S18S1G3
3 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 431
