Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Canon PowerShot SD1400 IS User Interface Panel Replacement
Neye ihtiyacın var
  1. Canon PowerShot SD1400 IS User Interface Panel Replacement, User Interface Panel: adım 1, 3 resimden 1. Canon PowerShot SD1400 IS User Interface Panel Replacement, User Interface Panel: adım 1, 3 resimden 2. Canon PowerShot SD1400 IS User Interface Panel Replacement, User Interface Panel: adım 1, 3 resimden 3.
    • Remove the 2.0 mm Phillips screws on both sides of the camera using the J00 bit from the 54 bit Driver Kit
    • There will be 4 total screws that need to be removed, 2 on each side
  2. Canon PowerShot SD1400 IS User Interface Panel Replacement: adım 2, 1 resimden 1.
    • Remove the 4.0 mm Phillips screw located on the bottom of the camera
  3. Canon PowerShot SD1400 IS User Interface Panel Replacement: adım 3, 1 resimden 1.
    • Remove the front face panel of the camera.
    • The face can be removed by hand with a firm pressure. If one point of the face is stuck to the body, ensure that there is not a screw remaining at that position to hold it in place.
  4. Canon PowerShot SD1400 IS User Interface Panel Replacement: adım 4, 1 resimden 1.
    • Remove the rear panel of the camera.
    • This can be done by hand without tools using firm pressure
  5. Canon PowerShot SD1400 IS User Interface Panel Replacement: adım 5, 1 resimden 1.
    • Remove the user interface panel by hand
    • The panel may fall out on its own, this is normal.
    • Replace the user interface panel by setting it in position.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Braxton Beal
696 İtibar
3 adet Kılavuz yazıldı
Ekip
Baylor, Team S1-G3, Johnson Spring 2018 Baylor, Team S1-G3, Johnson Spring 2018 üyesi
BU-JOHNSON-S18S1G3
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 240
