Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove the four 2.0 mm Phillips screws of the camera using the J00 bit from the 54-bit Driver Kit. There are two screws on both sides.
Remove the 4.0 mm Phillips screw located on the bottom of the camera.
Remove the front face panel of the camera by hand using firm pressure.
If one point of the face is stuck to the body, check if there is a screw preventing the front face from coming off.
Remove the rear panel of the camera by hand using firm pressure.
Remove the user interface panel by hand. The panel may fall out on its own, this is normal.
Replace the user interface panel by setting it in position.
2 farklı kişi bu kılavuzu tamamladı.
