Ana içeriğe geç
Canon PowerShot SD200 Battery Replacement
  1. Canon PowerShot SD200 Battery Replacement, Battery: adım 1, 3 resimden 1. Canon PowerShot SD200 Battery Replacement, Battery: adım 1, 3 resimden 2. Canon PowerShot SD200 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • The camera used to create these repair guides had a broken lens assembly. As a result, the lens is sticking out in all of the photos, but it is important to note that this should not be the case with your camera. The lens should retract itself back into the camera when it is turned off.
    • Use your fingernail to slide the dark gray tab located on the bottom of the device towards the edge of camera.
    • Slide the light gray door away from the LCD screen and pull up to open the door.
    • Both battery and memory card should now be visible.
  2. Canon PowerShot SD200 Battery Replacement: adım 2, 2 resimden 1. Canon PowerShot SD200 Battery Replacement: adım 2, 2 resimden 2.
    • Rotate the small brown tab towards the edge of the camera.
    • The battery should pop up.
  3. Canon PowerShot SD200 Battery Replacement: adım 3, 1 resimden 1.
    • Pull the battery straight out of the battery holder.
    • When putting the battery back in, make sure it is oriented the same as it was before.
Sonuç
James Loy
103 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-12, Maness Fall 2010 Cal Poly, Team 5-12, Maness Fall 2010 üyesi
CPSU-MANESS-F10S5G12
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 13
Her zaman: 2,975
