Ana içeriğe geç
Canon PowerShot SD200 Memory Card Replacement
  1. Canon PowerShot SD200 Memory Card Replacement, Memory Card: adım 1, 3 resimden 1. Canon PowerShot SD200 Memory Card Replacement, Memory Card: adım 1, 3 resimden 2. Canon PowerShot SD200 Memory Card Replacement, Memory Card: adım 1, 3 resimden 3.
    • Use your fingernail to slide the dark gray tab towards the edge of the camera.
    • Slide the light gray door away from the LCD screen and pull up to open the door.
    • The battery and the memory card slots should now be visible.
  2. Canon PowerShot SD200 Memory Card Replacement: adım 2, 1 resimden 1.
    • Press down on the memory card.
    • Memory card should pop out of place.
    • Pull the memory card straight out of the slot.
    • When putting the memory card back in, orient the memory card in the same direction when pulling out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
James Loy
103 İtibar
7 adet Kılavuz yazıldı
Cal Poly, Team 5-12, Maness Fall 2010 Cal Poly, Team 5-12, Maness Fall 2010 üyesi
CPSU-MANESS-F10S5G12
4 Üyeler
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 2,357
