Ana içeriğe geç
Canon PowerShot SD30 Control Panel Replacement
Neye ihtiyacın var
    1. Canon PowerShot SD30 Control Panel Replacement, Front Cover: adım 1, 2 resimden 1. Canon PowerShot SD30 Control Panel Replacement, Front Cover: adım 1, 2 resimden 2.
      • Be sure to remove the wrist strap and battery before removing the cover.
      • Remove the two 2mm black screws that are located on the underside of the camera.
      • Remove the two 3mm silver screws from the right side of camera.
      FixBot'a Sor
      Yorum Ekle
    2. Canon PowerShot SD30 Control Panel Replacement: adım 2, 1 resimden 1.
      • Gently remove the front cover.
      FixBot'a Sor
      Yorum Ekle
    1. Canon PowerShot SD30 Control Panel Replacement, Back Cover: adım 3, 3 resimden 1. Canon PowerShot SD30 Control Panel Replacement, Back Cover: adım 3, 3 resimden 2. Canon PowerShot SD30 Control Panel Replacement, Back Cover: adım 3, 3 resimden 3.
      • Remove the wrist strap and battery before removing the back cover.
      • Remove the 2mm screw from the back of the camera.
      • Remove two 2mm screws from the bottom of the camera.
      • Remove two 2mm screws the left side of camera.
      FixBot'a Sor
      Yorum Ekle
    2. Canon PowerShot SD30 Control Panel Replacement: adım 4, 1 resimden 1.
      • Gently remove the back cover.
      FixBot'a Sor
      Yorum Ekle
    1. Canon PowerShot SD30 Control Panel Replacement, Control Panel: adım 5, 3 resimden 1. Canon PowerShot SD30 Control Panel Replacement, Control Panel: adım 5, 3 resimden 2. Canon PowerShot SD30 Control Panel Replacement, Control Panel: adım 5, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Use the tweezers to pull up on the piece of black plastic connected to the ribbon to unhook and remove the ribbon connected to the screen.
      • You also have to pull up on the top part of the control panel because it is connected to the metal by a sticky pad.
      FixBot'a Sor
      Yorum Ekle
    2. Canon PowerShot SD30 Control Panel Replacement: adım 6, 3 resimden 1. Canon PowerShot SD30 Control Panel Replacement: adım 6, 3 resimden 2. Canon PowerShot SD30 Control Panel Replacement: adım 6, 3 resimden 3.
      • Turn the camera over to the side with the lens and remove the ribbon on the left side.
      • After removing the ribbon there will be a second ribbon to remove that was hiding underneath the first ribbon.
      FixBot'a Sor
      Yorum Ekle
    3. Canon PowerShot SD30 Control Panel Replacement: adım 7, 1 resimden 1.
      • Lift up the button that connects to the power button of the camera so you can remove the control panel.
      FixBot'a Sor
      Yorum Ekle
    4. Canon PowerShot SD30 Control Panel Replacement: adım 8, 1 resimden 1.
      • Remove the control panel from the camera.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 23
Her zaman: 586
