Ana içeriğe geç
Canon PowerShot SD30 Screen Replacement
Neye ihtiyacın var
  1. Canon PowerShot SD30 Screen Replacement, Front Cover: adım 1, 2 resimden 1. Canon PowerShot SD30 Screen Replacement, Front Cover: adım 1, 2 resimden 2.
    • Be sure to remove the wrist strap and battery before removing the cover.
    • Remove the two 2mm black screws that are located on the underside of the camera.
    • Remove the two 3mm silver screws from the right side of camera.
  2. Canon PowerShot SD30 Screen Replacement: adım 2, 1 resimden 1.
    • Gently remove the front cover.
  3. Canon PowerShot SD30 Screen Replacement, Back Cover: adım 3, 3 resimden 1. Canon PowerShot SD30 Screen Replacement, Back Cover: adım 3, 3 resimden 2. Canon PowerShot SD30 Screen Replacement, Back Cover: adım 3, 3 resimden 3.
    • Remove the wrist strap and battery before removing the back cover.
    • Remove the 2mm screw from the back of the camera.
    • Remove two 2mm screws from the bottom of the camera.
    • Remove two 2mm screws the left side of camera.
  4. Canon PowerShot SD30 Screen Replacement: adım 4, 1 resimden 1.
    • Gently remove the back cover.
  5. Canon PowerShot SD30 Screen Replacement, Screen: adım 5, 2 resimden 1. Canon PowerShot SD30 Screen Replacement, Screen: adım 5, 2 resimden 2.
    • Remove top button panel by removing the screw located at the top right of the panel.
  6. Canon PowerShot SD30 Screen Replacement: adım 6, 2 resimden 1. Canon PowerShot SD30 Screen Replacement: adım 6, 2 resimden 2.
    • Remove screws both at the top and the base of the screen to free the screen.
  7. Canon PowerShot SD30 Screen Replacement: adım 7, 3 resimden 1. Canon PowerShot SD30 Screen Replacement: adım 7, 3 resimden 2. Canon PowerShot SD30 Screen Replacement: adım 7, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use tweezers to lift the tab that secures the screen wire and remove.
    • You need to do this for both wires.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 16
Son 30 gün: 21
Her zaman: 199
