Ana içeriğe geç
Canon PowerShot SD400 Camera Case Replacement
Neye ihtiyacın var
  1. Canon PowerShot SD400 Camera Case Replacement, Camera Case: adım 1, 3 resimden 1. Canon PowerShot SD400 Camera Case Replacement, Camera Case: adım 1, 3 resimden 2. Canon PowerShot SD400 Camera Case Replacement, Camera Case: adım 1, 3 resimden 3.
    • Remove the 6 screws holding the casing in place located on the bottom, left and right sides of the camera using a Phillips Screwdriver.
    • Be sure to save the removed screws to allow for easier reassembly.
  2. Canon PowerShot SD400 Camera Case Replacement: adım 2, 2 resimden 1. Canon PowerShot SD400 Camera Case Replacement: adım 2, 2 resimden 2.
    • Gently separate the camera casing.
    • Once opened, the strap plate and disk pieces will also separate from the camera.
Sonuç
Yi Huang Ke
51 İtibar
4 adet Kılavuz yazıldı
Ekip
James Madison, Team 1-1, Allen Fall 2011 James Madison, Team 1-1, Allen Fall 2011 üyesi
JMU-ALLEN-F11S1G1
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 12
Her zaman: 1,935
