Ana içeriğe geç
Canon PowerShot SD400 LCD Replacement
Neye ihtiyacın var
  1. Canon PowerShot SD400 LCD Replacement, LCD: adım 1, 3 resimden 1. Canon PowerShot SD400 LCD Replacement, LCD: adım 1, 3 resimden 2. Canon PowerShot SD400 LCD Replacement, LCD: adım 1, 3 resimden 3.
    • Locate the 6 screws that you must remove to open the camera housing.
    • There are 2 screws on the bottom and 2 screws on each side
  2. Canon PowerShot SD400 LCD Replacement: adım 2, 3 resimden 1. Canon PowerShot SD400 LCD Replacement: adım 2, 3 resimden 2. Canon PowerShot SD400 LCD Replacement: adım 2, 3 resimden 3.
    • Using the screwdriver, carefully remove the exterior screws and set them aside to avoid misplacing them.
  3. Canon PowerShot SD400 LCD Replacement: adım 3, 2 resimden 1. Canon PowerShot SD400 LCD Replacement: adım 3, 2 resimden 2.
    • Locate the interior screw to the top right of the screen.
    • Remove the screw using the screwdriver.
  4. Canon PowerShot SD400 LCD Replacement: adım 4, 3 resimden 1. Canon PowerShot SD400 LCD Replacement: adım 4, 3 resimden 2. Canon PowerShot SD400 LCD Replacement: adım 4, 3 resimden 3.
    • Insert the flat-head screwdriver under the LCD screen into the two clips.
    • Lift the LCD screen.
    • Potential for device damage Lift the screen gently and be careful not to rip the screen off.
    Then what what to do next
    Keeneh Weah Cisco - Yanıt
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Yi Huang Ke
51 İtibar
4 adet Kılavuz yazıldı
Ekip
James Madison, Team 1-1, Allen Fall 2011 James Madison, Team 1-1, Allen Fall 2011 üyesi
JMU-ALLEN-F11S1G1
4 Üyeler
Bir Yorum
Do you carry a lcd screen for the Powershot sd400?
Jesus Licon - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 22
Her zaman: 3,024
