Ana içeriğe geç
Canon PowerShot SD450 Outer Case replacement
Neye ihtiyacın var
  1. Canon PowerShot SD450 Outer Case replacement, Casing: adım 1, 1 resimden 1.
    • Remove the battery and SD Card from their slots. Leaving these in could cause the battery to ground and ruin the electronics.
    • Unscrew the six screws on the casing. Two are on the bottom as pictured; two more are on each side of the camera.
  2. Canon PowerShot SD450 Outer Case replacement: adım 2, 1 resimden 1.
    • Pull the lanyard mount off of the camera using a spudger or your fingers.
  3. Canon PowerShot SD450 Outer Case replacement: adım 3, 2 resimden 1. Canon PowerShot SD450 Outer Case replacement: adım 3, 2 resimden 2.
    • Find the line that separates the casing into its two halves. Hold each half separately, and gently pull apart.
    • Note that there is a small metal clip holding the two halves together. It might help to press down on the back half (indicated) while pulling upward slightly on the front half.
  4. Canon PowerShot SD450 Outer Case replacement: adım 4, 1 resimden 1.
    • Take hold of the inside of the camera, and gently pull away from the back casing.
  5. Canon PowerShot SD450 Outer Case replacement: adım 5, 1 resimden 1.
    • Remove the square, clear, rubber protector from the front of the logic board. This is not necessary to remove, but can easily fall off and get lost during later steps.
  6. Canon PowerShot SD450 Outer Case replacement: adım 6, 1 resimden 1.
    • When you reassemble the camera, make sure the switch on the casing matches the position of the switch on the camera internals.
    • The black viewfinder padding can easily fall off the casing. Make sure you don't lose it when moving around parts.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Curtis Wagner
32 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 25-85, Amido Spring 2010 Cal Poly, Team 25-85, Amido Spring 2010 üyesi
CPSU-AMIDO-S10S25G85
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 3,532
