Giriş
The flash bulb is essential for to take dimly lit photographs. If the flash goes out, your camera will have severely limited functionality.
Neye ihtiyacın var
Slide open the battery cover.
Push the small orange tab to the side so the battery can be removed.
Two Phillips screws need to be removed using a #00 Phillips screwdriver. The upper screw is under the USB port cover, which can simply be pulled away gently from the casing. the lower screw is visible on the panel.
The screws are different sizes. The .125 inch screw is located under the USB port cover. The 0.85 inch screw goes in the lower hole on the panel.
Carefully wedge the pry tool under the ribbon in the ribbon gate.
Gently remove the ribbon from the ribbon gate by pulling it away from the gate with the pry tool.
Arrange camera so it is facing up towards you.
Unscrew one .01 inch Phillips screw using a #00 Phillips screwdriver from the front of the camera.
