Giriş
The outer case of the PowerShot SD500 Digital ELPH camera is the part that takes the greatest beating. Every time the camera falls, it lands on its case. Some common problems include cracking and paint wear.
Parçalar
Hiçbir parçaya gerek yok.
  1. Slide open the battery cover.
    • Slide open the battery cover.
    • Push the small orange tab to the side so the battery can be removed.
  2. Slide the battery out of the battery compartment. Slide the battery out of the battery compartment.
    • Slide the battery out of the battery compartment.
  3. Two Phillips screws need to be removed  using a #00 Phillips screwdriver. The upper screw is under the USB port cover, which can simply be pulled away gently from the casing.  the lower screw is visible on the panel. The screws are different sizes. The .125 inch screw is located under the USB port cover. The 0.85 inch screw goes in the lower hole on the panel.
    • Two Phillips screws need to be removed using a #00 Phillips screwdriver. The upper screw is under the USB port cover, which can simply be pulled away gently from the casing. the lower screw is visible on the panel.
    • The screws are different sizes. The .125 inch screw is located under the USB port cover. The 0.85 inch screw goes in the lower hole on the panel.
    • When looking at the back of the camera, these two screws are on the right panel of the camera.
  4. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  5. Remove the right side cover from the camera casing.
    • Remove the right side cover from the camera casing.
  6. Remove a .07 inch Phillips screw using a #00 Phillips screwdriver.
    • Remove a .07 inch Phillips screw using a #00 Phillips screwdriver.
  7. Remove two .085 inch Phillips screws from the left side of the camera using a #00 Philips screwdriver.
    • Remove two .085 inch Phillips screws from the left side of the camera using a #00 Philips screwdriver.
  8. Remove the left side cover from the camera.
    • Remove the left side cover from the camera.
  9. Remove three .15 inch Phillips screws from the bottom of the camera using a #00 Phillips screwdriver.
    • Remove three .15 inch Phillips screws from the bottom of the camera using a #00 Phillips screwdriver.
  10. Once the casing is unscrewed, hold the camera with one side facing down, and lift the opposite face of the casing to open it. Remove the internal camera components and layout out all pieces on a clean surface.
    • Once the casing is unscrewed, hold the camera with one side facing down, and lift the opposite face of the casing to open it.
    • Remove the internal camera components and layout out all pieces on a clean surface.
    • The front and back cover may require gentle rocking to remove.
Sonuç
Taylor Shields
831 İtibar
8 adet Kılavuz yazıldı
Takım
Clemson, Team 2-1, Benson Fall 2014 Clemson, Team 2-1, Benson Fall 2014 üyesi
CLEM-BENSON-F14S2G1
4 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 103
