Ana içeriğe geç
Canon PowerShot SD500 Digital ELPH Image Sensor Replacement
Neye ihtiyacın var
  1. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement, Battery: adım 1, 1 resimden 1.
    • Slide open the battery cover.
    • Push the small orange tab to the side so the battery can be removed.
  2. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: adım 2, 2 resimden 1. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: adım 2, 2 resimden 2.
    • Slide the battery out of the battery compartment.
  3. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement, Front and Rear Casing: adım 3, 2 resimden 1. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement, Front and Rear Casing: adım 3, 2 resimden 2.
    • Two Phillips screws need to be removed using a #00 Phillips screwdriver. The upper screw is under the USB port cover, which can simply be pulled away gently from the casing. the lower screw is visible on the panel.
    • The screws are different sizes. The .125 inch screw is located under the USB port cover. The 0.85 inch screw goes in the lower hole on the panel.
    • When looking at the back of the camera, these two screws are on the right panel of the camera.
  4. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: adım 4, 1 resimden 1.
    • Remove the right side cover from the camera casing.
  5. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: adım 5, 1 resimden 1.
    • Remove a .07 inch Phillips screw using a #00 Phillips screwdriver.
  6. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: adım 6, 1 resimden 1.
    • Remove two .085 inch Phillips screws from the left side of the camera using a #00 Philips screwdriver.
  7. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: adım 7, 1 resimden 1.
    • Remove the left side cover from the camera.
  8. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: adım 8, 1 resimden 1.
    • Remove three .15 inch Phillips screws from the bottom of the camera using a #00 Phillips screwdriver.
  9. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: adım 9, 2 resimden 1. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: adım 9, 2 resimden 2.
    • Once the casing is unscrewed, hold the camera with one side facing down, and lift the opposite face of the casing to open it.
    • Remove the internal camera components and layout out all pieces on a clean surface.
    • The front and back cover may require gentle rocking to remove.
  10. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement, Button Contact Panel: adım 10, 1 resimden 1.
    • Carefully wedge the pry tool under the ribbon in the ribbon gate.
    • Gently remove the ribbon from the ribbon gate by pulling it away from the gate with the pry tool.
    • Be careful not to damage the ribbon.
  11. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: adım 11, 1 resimden 1.
    • Gently press the ribbon back to get access to a Phillips screw behind it.
    • Unscrew two .125 inch long Phillips screws using a #00 Philips screwdriver.
  12. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: adım 12, 3 resimden 1. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: adım 12, 3 resimden 2. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: adım 12, 3 resimden 3.
    • Remove the ribbon with a pry tool by gently pulling it out of the ribbon gate tab.
    • Pull the button board away from the rest of the camera.
  13. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement, LCD: adım 13, 1 resimden 1.
    • Unscrew one .113 inch Phillips screw using a #00 Phillips screwdriver.
  14. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: adım 14, 1 resimden 1.
    • Lift the LCD screen up and away from the tab that holds it in place on the face of the camera.
    • Be careful, the LCD screen is still connect to the camera by a ribbon cable.
  15. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: adım 15, 2 resimden 1. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: adım 15, 2 resimden 2.
    • Gently press the pry tool under the ribbon gate and lift up to free the ribbon connecting the LCD to the circuit board.
    • The LCD can now be completely removed from the camera.
  16. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement, Image Sensor: adım 16, 1 resimden 1.
    • Place the pry tool under ribbon gate and gently lift it up, disconnecting the ribbon.
  17. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: adım 17, 1 resimden 1.
    • Unscrew three .15 inch Phillips screws from the back of the camera using a #00 Phillips screwdriver.
  18. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: adım 18, 2 resimden 1. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: adım 18, 2 resimden 2.
    • Use the pry tool to gently lift the image sensor away from the rest of the camera.
    • Be careful not to damage the image sensor as you pry it up.
Sonuç
Taylor Shields
846 İtibar
8 adet Kılavuz yazıldı
Ekip
Clemson, Team 2-1, Benson Fall 2014 Clemson, Team 2-1, Benson Fall 2014 üyesi
CLEM-BENSON-F14S2G1
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 16
Her zaman: 388
