Ana içeriğe geç
Canon PowerShot SD500 Digital ELPH Shutter Button Replacement
Neye ihtiyacın var
  1. Canon PowerShot SD500 Digital ELPH Shutter Button Replacement, Battery: adım 1, 1 resimden 1.
    • Slide open the battery cover.
    • Push the small orange tab to the side so the battery can be removed.
  2. Canon PowerShot SD500 Digital ELPH Shutter Button Replacement: adım 2, 2 resimden 1. Canon PowerShot SD500 Digital ELPH Shutter Button Replacement: adım 2, 2 resimden 2.
    • Slide the battery out of the battery compartment.
  3. Canon PowerShot SD500 Digital ELPH Shutter Button Replacement, Front and Rear Casing: adım 3, 2 resimden 1. Canon PowerShot SD500 Digital ELPH Shutter Button Replacement, Front and Rear Casing: adım 3, 2 resimden 2.
    • Two Phillips screws need to be removed using a #00 Phillips screwdriver. The upper screw is under the USB port cover, which can simply be pulled away gently from the casing. the lower screw is visible on the panel.
    • The screws are different sizes. The .125 inch screw is located under the USB port cover. The 0.85 inch screw goes in the lower hole on the panel.
    • When looking at the back of the camera, these two screws are on the right panel of the camera.
  4. Canon PowerShot SD500 Digital ELPH Shutter Button Replacement: adım 4, 1 resimden 1.
    • Remove the right side cover from the camera casing.
  5. Canon PowerShot SD500 Digital ELPH Shutter Button Replacement: adım 5, 1 resimden 1.
    • Remove a .07 inch Phillips screw using a #00 Phillips screwdriver.
  6. Canon PowerShot SD500 Digital ELPH Shutter Button Replacement: adım 6, 1 resimden 1.
    • Remove two .085 inch Phillips screws from the left side of the camera using a #00 Philips screwdriver.
  7. Canon PowerShot SD500 Digital ELPH Shutter Button Replacement: adım 7, 1 resimden 1.
    • Remove the left side cover from the camera.
  8. Canon PowerShot SD500 Digital ELPH Shutter Button Replacement: adım 8, 1 resimden 1.
    • Remove three .15 inch Phillips screws from the bottom of the camera using a #00 Phillips screwdriver.
  9. Canon PowerShot SD500 Digital ELPH Shutter Button Replacement: adım 9, 2 resimden 1. Canon PowerShot SD500 Digital ELPH Shutter Button Replacement: adım 9, 2 resimden 2.
    • Once the casing is unscrewed, hold the camera with one side facing down, and lift the opposite face of the casing to open it.
    • Remove the internal camera components and layout out all pieces on a clean surface.
    • The front and back cover may require gentle rocking to remove.
  10. Canon PowerShot SD500 Digital ELPH Shutter Button Replacement, Shutter Button: adım 10, 1 resimden 1.
    • Unscrew one .235 inch long Phillips screw using a #00 Phillips screwdriver from the top of the camera.
  11. Canon PowerShot SD500 Digital ELPH Shutter Button Replacement: adım 11, 1 resimden 1.
    • Gently remove the shutter button unit from the rest of the camera.
Sonuç
Taylor Shields
846 İtibar
8 adet Kılavuz yazıldı
Ekip
Clemson, Team 2-1, Benson Fall 2014 Clemson, Team 2-1, Benson Fall 2014 üyesi
CLEM-BENSON-F14S2G1
4 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 137
