Ana içeriğe geç
Canon PowerShot SD700 E18 Error Replacement
Neye ihtiyacın var
  1. Canon PowerShot SD700 E18 Error Replacement, Outside Case: adım 1, 1 resimden 1.
    • Turn off the camera by pressing the power button above the LCD screen.
  2. Canon PowerShot SD700 E18 Error Replacement: adım 2, 1 resimden 1.
    • Remove the two small screws on the bottom of the camera using a Phillips #00 screwdriver.
  3. Canon PowerShot SD700 E18 Error Replacement: adım 3, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the two small screws on the right side of the camera.
  4. Canon PowerShot SD700 E18 Error Replacement: adım 4, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the screw on the left of the camera under the A/V out digital label.
  5. Canon PowerShot SD700 E18 Error Replacement: adım 5, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the screw on the bottom of the camera near the battery and memory card slots.
    • This screw will be longer than the rest of the screws.
  6. Canon PowerShot SD700 E18 Error Replacement: adım 6, 1 resimden 1.
    • Remove the front, back, and side casings from the camera and set to the side.
  7. Bu adımda kullanılan alet:
    Dust Blower
    • Clean the lens and the area surrounding the lens with a soft brush and dust blower.
    • Tweezers can be helpful when removing sand.
    • Reassemble the camera and if the E18 error persists, further disassembly of the camera may be required.
Sonuç
To reassemble your device, follow steps 1-6 instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
Aaron Lee
212 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-71, Walters Spring 2011 Cal Poly, Team 9-71, Walters Spring 2011 üyesi
CPSU-WALTERS-S11S9G71
4 Üyeler
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 13
Son 30 gün: 41
Her zaman: 3,179
