Ana içeriğe geç
Canon PowerShot SD700 LCD screen Replacement
Neye ihtiyacın var
  1. Canon PowerShot SD700 LCD screen Replacement, Outside Case: adım 1, 1 resimden 1.
    • Turn off the camera by pressing the power button above the LCD screen.
  2. Canon PowerShot SD700 LCD screen Replacement: adım 2, 1 resimden 1.
    • Remove the two small screws on the bottom of the camera using a Phillips #00 screwdriver.
  3. Canon PowerShot SD700 LCD screen Replacement: adım 3, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the two small screws on the right side of the camera.
  4. Canon PowerShot SD700 LCD screen Replacement: adım 4, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the screw on the left of the camera under the A/V out digital label.
  5. Canon PowerShot SD700 LCD screen Replacement: adım 5, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the screw on the bottom of the camera near the battery and memory card slots.
    • This screw will be longer than the rest of the screws.
  6. Canon PowerShot SD700 LCD screen Replacement: adım 6, 1 resimden 1.
    • Remove the front, back, and side casings from the camera and set to the side.
  7. Canon PowerShot SD700 LCD screen Replacement, LCD screen: adım 7, 1 resimden 1.
    • Remove the two screws that connect the LCD and backlight to the main body of the camera.
  8. Canon PowerShot SD700 LCD screen Replacement: adım 8, 3 resimden 1. Canon PowerShot SD700 LCD screen Replacement: adım 8, 3 resimden 2. Canon PowerShot SD700 LCD screen Replacement: adım 8, 3 resimden 3.
    • Gently pry the LCD and the backlight from the main body of the camera.
    • Gently pry the LCD from the backlight.
    • The thin ribbon cable is for the backlight.
    • The thick ribbon cable is for the LCD screen.
  9. Canon PowerShot SD700 LCD screen Replacement: adım 9, 1 resimden 1.
    • Carefully lift the ZIF connector that covers the thick ribbon cable.
    • This ZIF connector is fragile. Use caution when lifting it from its down position.
    • Insert the new LCD and reassemble the camera.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Emilio Rossi
113 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-71, Walters Spring 2011 Cal Poly, Team 9-71, Walters Spring 2011 üyesi
CPSU-WALTERS-S11S9G71
4 Üyeler
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 26
Her zaman: 2,722
