Ana içeriğe geç
Canon PowerShot SD800 IS LCD Assembly Replacement
Neye ihtiyacın var
  1. Canon PowerShot SD800 IS LCD Assembly Replacement, Back Cover: adım 1, 1 resimden 1.
    • Remove one 2.25mm screw on the bottom.
  2. Canon PowerShot SD800 IS LCD Assembly Replacement: adım 2, 1 resimden 1.
    • Remove two 2.25mm screws on the right side looking from the front.
  3. Canon PowerShot SD800 IS LCD Assembly Replacement: adım 3, 1 resimden 1.
    • Remove one 4.7mm screw on the side with the AV output.
  4. Canon PowerShot SD800 IS LCD Assembly Replacement: adım 4, 1 resimden 1.
    • Pull off the back cover.
    • The back cover tends to stick in the top corner (near the mode dial) due to a metal clip. Jiggle the cover side to side as you pull it out.
  5. Canon PowerShot SD800 IS LCD Assembly Replacement, LCD Assembly: adım 5, 1 resimden 1.
    • Remove 2 2.4mm screws on bottom.
  6. Canon PowerShot SD800 IS LCD Assembly Replacement: adım 6, 1 resimden 1.
    • Follow the small data cable to where it connects to the camera.
    • Lift the back white portion to unlock the cable.
    • The cable should easily slide out.
    • The connector is very fragile. Use caution when lifting the lock.
  7. Canon PowerShot SD800 IS LCD Assembly Replacement: adım 7, 1 resimden 1.
    • Gently lift LCD display off.
    • There will be two data cables still attached to the camera. Do not break them.
    • There may be a loose strip of metal along the inner side of the LCD display for a secure fit.
  8. Canon PowerShot SD800 IS LCD Assembly Replacement: adım 8, 1 resimden 1.
    • Follow the larger cable to where it connects to the camera.
    • Lift the front black portion of the connector to unlock the data cable.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jeremy Rabaino
135 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-9, Maness Fall 2010 Cal Poly, Team 20-9, Maness Fall 2010 üyesi
CPSU-MANESS-F10S20G9
5 Üyeler
Bir Yorum
where can I buy a replacement LCD screen for a SD800 IS
ALFRED - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 2,275
