Ana içeriğe geç
Canon PowerShot SD850 IS Function Set Button Replacement
Neye ihtiyacın var
  1. Canon PowerShot SD850 IS Function Set Button Replacement, Battery: adım 1, 3 resimden 1. Canon PowerShot SD850 IS Function Set Button Replacement, Battery: adım 1, 3 resimden 2. Canon PowerShot SD850 IS Function Set Button Replacement, Battery: adım 1, 3 resimden 3.
    • Slide the light grey tab toward the edge of the camera using your fingernail.
    • Pull the light grey tab up to open the door.
    • These photos do not show the camera’s memory card or battery, which should be visible inside.
  2. Canon PowerShot SD850 IS Function Set Button Replacement: adım 2, 2 resimden 1. Canon PowerShot SD850 IS Function Set Button Replacement: adım 2, 2 resimden 2.
    • Slide the small brown tab toward the edge of the camera using your fingernail.
    • Let go of the brown tab when the battery pops up.
    • Grab battery and pull straight up to remove from holder.
    • When inserting the battery, orient it so that the terminals connect.
  3. Canon PowerShot SD850 IS Function Set Button Replacement, Case: adım 3, 2 resimden 1. Canon PowerShot SD850 IS Function Set Button Replacement, Case: adım 3, 2 resimden 2.
    • Remove the following 4 screws:
    • Two 2.8 mm Phillips #00 at the bottom of the camera.
    • Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
  4. Canon PowerShot SD850 IS Function Set Button Replacement: adım 4, 3 resimden 1. Canon PowerShot SD850 IS Function Set Button Replacement: adım 4, 3 resimden 2. Canon PowerShot SD850 IS Function Set Button Replacement: adım 4, 3 resimden 3.
    • Open the A/V OUT DIGITAL flap on the side of the wrist strap.
    • Remove the 2.75 mm Phillips #00 under the A/V OUT DIGITAL flap on the side of the wrist strap.
  5. Canon PowerShot SD850 IS Function Set Button Replacement: adım 5, 2 resimden 1. Canon PowerShot SD850 IS Function Set Button Replacement: adım 5, 2 resimden 2.
    • On the bottom of the camera, use your fingernail to slide the light gray tab towards the edge of the camera.
    • Slide light gray door and pull up to open the door.
    • Remove the 8.35 mm Phillips #00 next to the brown tab that holds the battery.
  6. Canon PowerShot SD850 IS Function Set Button Replacement: adım 6, 2 resimden 1. Canon PowerShot SD850 IS Function Set Button Replacement: adım 6, 2 resimden 2.
    • Gently pull the front cover straight out from the camera. This will expose the wiring on the front of the camera.
  7. Canon PowerShot SD850 IS Function Set Button Replacement: adım 7, 1 resimden 1.
    • Remove the 2.75 mm Phillips #00 next to A/V OUT DIGITAL.
  8. Canon PowerShot SD850 IS Function Set Button Replacement: adım 8, 1 resimden 1.
    • Slide the back casing (with the screen protector) off to reveal the LCD and back wiring.
  9. Canon PowerShot SD850 IS Function Set Button Replacement, Function Set Button: adım 9, 2 resimden 1. Canon PowerShot SD850 IS Function Set Button Replacement, Function Set Button: adım 9, 2 resimden 2.
    • Identify and remove the plastic function set button. Do this by gently prying up as indicated in the photo.
  10. Canon PowerShot SD850 IS Function Set Button Replacement: adım 10, 1 resimden 1.
    • Lift the function set button ribbon cable from the two guide pins.
  11. Canon PowerShot SD850 IS Function Set Button Replacement: adım 11, 1 resimden 1.
    • Remove the ribbon cable by lifting on the flat tab and pulling the ribbon cable from the connection.
Sonuç
iDeleted
2.101 İtibar
39 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 1,287
