Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Use this guide to replace or repair a broken battery or memory card slot on your Canon PowerShot SD870 IS.
Neye ihtiyacın var
The first screw that needs to be removed is located on the bottom of the camera, on the left hand side.
Using a Phillips #00 screwdriver remove the 0.133in silver screw on the bottom left-hand side.
The LCD screen should now only be attached by the LCD data cable.
Lift the screen from the right side and use a small screwdriver or other small opening device to flip the black portion of the connector upward to unlock it.
Carefully slide the data cable out of the connector.
The LCD should still be connected by the backlight cable.
The LCD screen casing is connected by 4 claws located on the top and bottom on the left and right hand side.
Carefully disengage the claws by gently prying them off one by one.
Once the claws are disengaged, the back of the casing will still be connected to the front casing by the backlight cable.
Carefully peel the backlight cable off of the casing.
With the case and LCD screen removed, you are ready to remove the release button.
Begin by using the Philips #00 screwdriver to remove two silver 0.159in screws on the top and front of the camera.
With the case, LCD screen, and release button housing removed, the logic board can be accessed and removed for replacement or repair.
Begin by using the Philips #00 screwdriver to remove two silver 0.080in screws on the left side of the metal housing plate (yellow circles).
Use the Philips #00 screwdriver to remove nine silver screws from the back and top of the camera (red circles).
With everything removed, the battery and memory card slot can be accessed and replaced easily.
Begin by removing the wire to the LED on the front of the camera.
