Ana içeriğe geç
Canon PowerShot SD870 IS Flash Assembly Replacement
Neye ihtiyacın var
  1. Canon PowerShot SD870 IS Flash Assembly Replacement, Outer Case: adım 1, 1 resimden 1.
    • Remove the wrist strap, if present.
    • Remove the lithium-ion battery.
  2. Canon PowerShot SD870 IS Flash Assembly Replacement: adım 2, 3 resimden 1. Canon PowerShot SD870 IS Flash Assembly Replacement: adım 2, 3 resimden 2. Canon PowerShot SD870 IS Flash Assembly Replacement: adım 2, 3 resimden 3.
    • Remove the two 4 mm Phillips #00 screws on the bottom of the camera.
    • Remove the screw next to the wrist strap attachment.
    • Pull up the “A/V OUT DIGITAL” cover and remove the screw above the USB port.
  3. Canon PowerShot SD870 IS Flash Assembly Replacement: adım 3, 1 resimden 1.
    • Carefully unhook the “A/V OUT DIGITAL” cover from the hinge.
  4. Canon PowerShot SD870 IS Flash Assembly Replacement: adım 4, 2 resimden 1. Canon PowerShot SD870 IS Flash Assembly Replacement: adım 4, 2 resimden 2.
    • Pull the front cover from the camera by using gentle upward pressure.
  5. Canon PowerShot SD870 IS Flash Assembly Replacement: adım 5, 2 resimden 1. Canon PowerShot SD870 IS Flash Assembly Replacement: adım 5, 2 resimden 2.
    • Remove the two Phillips #00 screws from the flat end of the camera.
    • Remove the black L-shaped side cover plate.
    • Remove the silver u-shaped retainer plate.
  6. Canon PowerShot SD870 IS Flash Assembly Replacement: adım 6, 1 resimden 1.
    • Slide the back casing off.
  7. Canon PowerShot SD870 IS Flash Assembly Replacement, LCD: adım 7, 1 resimden 1.
    • The first screw that needs to be removed is located on the bottom of the camera, on the left hand side.
    • Using a Phillips #00 screwdriver remove the 0.133in silver screw on the bottom left-hand side.
  8. Canon PowerShot SD870 IS Flash Assembly Replacement: adım 8, 2 resimden 1. Canon PowerShot SD870 IS Flash Assembly Replacement: adım 8, 2 resimden 2.
    • The second screw that needs to be removed is located on the top of the camera.
    • Using the same Phillips head screwdriver, remove the last 0.133in silver screw.
    • This will detach a silver U-shaped piece that was holding LCD screen on. Remove the piece and put it to the side.
  9. Canon PowerShot SD870 IS Flash Assembly Replacement: adım 9, 1 resimden 1.
    • The LCD screen should now only be attached by the LCD data cable.
    • Lift the screen from the right side and use a small screwdriver or other small opening device to flip the black portion of the connector upward to unlock it.
    • Carefully slide the data cable out of the connector.
    • The LCD should still be connected by the backlight cable.
  10. Canon PowerShot SD870 IS Flash Assembly Replacement: adım 10, 2 resimden 1. Canon PowerShot SD870 IS Flash Assembly Replacement: adım 10, 2 resimden 2.
    • To remove the backlight cable, use another small opening device to unlock the backlight cable.
    • Carefully slide out the backlight cable.
    • The LCD screen should now be fully detached from the camera body.
  11. Canon PowerShot SD870 IS Flash Assembly Replacement: adım 11, 1 resimden 1.
    • The LCD screen casing is connected by 4 claws located on the top and bottom on the left and right hand side.
    • Carefully disengage the claws by gently prying them off one by one.
    • Once the claws are disengaged, the back of the casing will still be connected to the front casing by the backlight cable.
    • Carefully peel the backlight cable off of the casing.
  12. Canon PowerShot SD870 IS Flash Assembly Replacement: adım 12, 1 resimden 1.
    • The LCD screen and housing should now be in three pieces:
    • LCD screen
    • LCD screen frame
    • LCD screen back housing
    • The LCD screen itself can now be removed and fixed/replaced.
  13. Canon PowerShot SD870 IS Flash Assembly Replacement, Shutter Release Button: adım 13, 2 resimden 1. Canon PowerShot SD870 IS Flash Assembly Replacement, Shutter Release Button: adım 13, 2 resimden 2.
    • With the case and LCD screen removed, you are ready to remove the release button.
    • Begin by using the Philips #00 screwdriver to remove two silver 0.159in screws on the top and front of the camera.
  14. Canon PowerShot SD870 IS Flash Assembly Replacement: adım 14, 1 resimden 1.
    • The top plastic piece holding the release button should be held on only by a red-and-black wire connector to the logic board.
    • Remove the connector from the logic board and detach the release button housing from the camera.
  15. Canon PowerShot SD870 IS Flash Assembly Replacement: adım 15, 2 resimden 1. Canon PowerShot SD870 IS Flash Assembly Replacement: adım 15, 2 resimden 2.
    • With the plastic housing for the release button removed from the camera, use the Philips #00 screwdriver to remove two silver 0.090in screws.
    • The release button can now be removed and fixed or replaced.
  16. Canon PowerShot SD870 IS Flash Assembly Replacement, Flash Assembly: adım 16, 1 resimden 1.
    • Begin by removing two silver 0.080in screw on the left side of the camera.
  17. Canon PowerShot SD870 IS Flash Assembly Replacement: adım 17, 1 resimden 1.
    • With the case, LCD screen, and release button housing removed, the broken flash unit can be removed and replaced.
    • Begin by disconnecting the hanging flash/speaker unit from the connector on top of the camera.
  18. Canon PowerShot SD870 IS Flash Assembly Replacement: adım 18, 1 resimden 1.
    • Next, gently disconnect the plastic piece on top of the flash/speaker wiring by prying open the claws on either side.
    • The flash unit can now be removed and replaced.
    • Be careful not to touch the capacitor attached to the flash unit as it may still be holding a charge!
Sonuç
Sam
155 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-45, Garner Spring 2010 Cal Poly, Team 10-45, Garner Spring 2010 üyesi
CPSU-GARNER-S10S10G45
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 4,934
