Ana içeriğe geç
Canon PowerShot SD870 IS Outer Case Replacement
Neye ihtiyacın var
  1. Canon PowerShot SD870 IS Outer Case Replacement, Outer Case: adım 1, 1 resimden 1.
    • Remove the wrist strap, if present.
    • Remove the lithium-ion battery.
  2. Canon PowerShot SD870 IS Outer Case Replacement: adım 2, 3 resimden 1. Canon PowerShot SD870 IS Outer Case Replacement: adım 2, 3 resimden 2. Canon PowerShot SD870 IS Outer Case Replacement: adım 2, 3 resimden 3.
    • Remove the two 4 mm Phillips #00 screws on the bottom of the camera.
    • Remove the screw next to the wrist strap attachment.
    • Pull up the “A/V OUT DIGITAL” cover and remove the screw above the USB port.
  3. Canon PowerShot SD870 IS Outer Case Replacement: adım 3, 1 resimden 1.
    • Carefully unhook the “A/V OUT DIGITAL” cover from the hinge.
  4. Canon PowerShot SD870 IS Outer Case Replacement: adım 4, 2 resimden 1. Canon PowerShot SD870 IS Outer Case Replacement: adım 4, 2 resimden 2.
    • Pull the front cover from the camera by using gentle upward pressure.
  5. Canon PowerShot SD870 IS Outer Case Replacement: adım 5, 2 resimden 1. Canon PowerShot SD870 IS Outer Case Replacement: adım 5, 2 resimden 2.
    • Remove the two Phillips #00 screws from the flat end of the camera.
    • Remove the black L-shaped side cover plate.
    • Remove the silver u-shaped retainer plate.
  6. Canon PowerShot SD870 IS Outer Case Replacement: adım 6, 1 resimden 1.
    • Slide the back casing off.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Zach pelley
79 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 10-45, Garner Spring 2010 Cal Poly, Team 10-45, Garner Spring 2010 üyesi
CPSU-GARNER-S10S10G45
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 8,282
