Ana içeriğe geç
Canon PowerShot SX150 IS Buttons Replacement
Neye ihtiyacın var
    1. Canon PowerShot SX150 IS Buttons Replacement, Canon PowerShot SX150 IS Battery Removal: adım 1, 3 resimden 1. Canon PowerShot SX150 IS Buttons Replacement, Canon PowerShot SX150 IS Battery Removal: adım 1, 3 resimden 2. Canon PowerShot SX150 IS Buttons Replacement, Canon PowerShot SX150 IS Battery Removal: adım 1, 3 resimden 3.
      • Locate the battery cover on the bottom of the camera.
      • Slide the battery compartment cover the direction the arrow is pointing to open the compartment.
      • Remove batteries.
      FixBot'a Sor
      Yorum Ekle
    1. Canon PowerShot SX150 IS Buttons Replacement, Buttons: adım 2, 3 resimden 1. Canon PowerShot SX150 IS Buttons Replacement, Buttons: adım 2, 3 resimden 2. Canon PowerShot SX150 IS Buttons Replacement, Buttons: adım 2, 3 resimden 3.
      • Remove the two, 2mm screws from the top of the screen. Using the J000 screwdriver.
      • Remove the 3, 5mm screws on either side of the camera. continue to use the same screwdriver from step 1.
      FixBot'a Sor
      Yorum Ekle
    2. Canon PowerShot SX150 IS Buttons Replacement: adım 3, 1 resimden 1.
      • Remove the two, 4mm screws from the bottom of the camera. Continue using the same screwdriver from step 1.
      FixBot'a Sor
      Yorum Ekle
    3. Canon PowerShot SX150 IS Buttons Replacement: adım 4, 1 resimden 1.
      • Remove back plate from the camera and locate the orange button plate to the right of the screen.
      FixBot'a Sor
      Yorum Ekle
    4. Canon PowerShot SX150 IS Buttons Replacement: adım 5, 3 resimden 1. Canon PowerShot SX150 IS Buttons Replacement: adım 5, 3 resimden 2. Canon PowerShot SX150 IS Buttons Replacement: adım 5, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Once the back plate is removed. Locate the buttons to the right of the screen.
      • Using the tweezers carefully lift up the tabs connecting the buttons to the button plate.
      • After lifting the tabs the buttons should come right off, then replace with the new button.
      FixBot'a Sor
      Yorum Ekle
Sonuç
1Rehber Yorum
Where do you buy replacement buttons/parts. Canon offers service but i don’t see parts?
robert jones - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 25
Her zaman: 953
