Ana içeriğe geç
Canon PowerShot SX150 IS Digital Image Sensor Replacement
Neye ihtiyacın var
    1. Canon PowerShot SX150 IS Digital Image Sensor Replacement, Canon PowerShot SX150 IS Battery Removal: adım 1, 3 resimden 1. Canon PowerShot SX150 IS Digital Image Sensor Replacement, Canon PowerShot SX150 IS Battery Removal: adım 1, 3 resimden 2. Canon PowerShot SX150 IS Digital Image Sensor Replacement, Canon PowerShot SX150 IS Battery Removal: adım 1, 3 resimden 3.
      • Locate the battery cover on the bottom of the camera.
      • Slide the battery compartment cover the direction the arrow is pointing to open the compartment.
      • Remove batteries.
      FixBot'a Sor
      Yorum Ekle
    1. Canon PowerShot SX150 IS Digital Image Sensor Replacement, Canon PowerShot SX150 IS Prerequisite: adım 2, 1 resimden 1.
      • Remove the two 2mm screws above the screen using the size J000 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Canon PowerShot SX150 IS Digital Image Sensor Replacement: adım 3, 2 resimden 1. Canon PowerShot SX150 IS Digital Image Sensor Replacement: adım 3, 2 resimden 2.
      • Remove the two 5mm screws from the side of the camera with the J000 head screw driver.
      • Using the same screwdriver, remove the one 5mm screw from the other side of the camera located under the A/V Out flap.
      FixBot'a Sor
      Yorum Ekle
    3. Canon PowerShot SX150 IS Digital Image Sensor Replacement: adım 4, 1 resimden 1.
      • Remove two 4mm screws from the bottom of the camera with the J000 head screw driver.
      FixBot'a Sor
      Yorum Ekle
    4. Canon PowerShot SX150 IS Digital Image Sensor Replacement: adım 5, 1 resimden 1.
      • Remove the plastic panel surrounding the back screen.
      FixBot'a Sor
      Yorum Ekle
    5. Canon PowerShot SX150 IS Digital Image Sensor Replacement: adım 6, 3 resimden 1. Canon PowerShot SX150 IS Digital Image Sensor Replacement: adım 6, 3 resimden 2. Canon PowerShot SX150 IS Digital Image Sensor Replacement: adım 6, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Remove the three 3mm screws using the size J000 screw driver from the button plate.
      • Gently flip up the flex ribbon lock and remove the flex ribbon using tweezers.
      • Move the button plate out of the way.
      FixBot'a Sor
      Yorum Ekle
    6. Canon PowerShot SX150 IS Digital Image Sensor Replacement: adım 7, 2 resimden 1. Canon PowerShot SX150 IS Digital Image Sensor Replacement: adım 7, 2 resimden 2.
      • There is a black flex ribbon lock that must be lifted and unlocked with your tweezers before this flex ribbon will detach.
      • Any small tear could ruin the flex ribbon. Be very gentle while removing it.
      • Gently lift the lock and detach the flex ribbon from the circuit board with the tweezers.
      FixBot'a Sor
      Yorum Ekle
    7. Canon PowerShot SX150 IS Digital Image Sensor Replacement: adım 8, 1 resimden 1.
      • Remove the two 2mm screws from the bottom of the screen with the size J000 screw driver.
      • You can then lift the screen out of place and set it aside.
      FixBot'a Sor
      Yorum Ekle
    8. Canon PowerShot SX150 IS Digital Image Sensor Replacement: adım 9, 3 resimden 1. Canon PowerShot SX150 IS Digital Image Sensor Replacement: adım 9, 3 resimden 2. Canon PowerShot SX150 IS Digital Image Sensor Replacement: adım 9, 3 resimden 3.
      • With the J000 Philips head screwdriver, remove the two 2mm screws from under the flash.
      • Using the same screwdriver, remove the two 5mm screws from the bottom. One is under the battery door.
      • With the same screwdriver, remove the 2mm screw at the top of the metal plate.
      FixBot'a Sor
      Yorum Ekle
    9. Canon PowerShot SX150 IS Digital Image Sensor Replacement: adım 10, 2 resimden 1. Canon PowerShot SX150 IS Digital Image Sensor Replacement: adım 10, 2 resimden 2.
      • Gently detach the flex ribbon with your tweezers before removing the front plate.
      FixBot'a Sor
      Yorum Ekle
    10. Canon PowerShot SX150 IS Digital Image Sensor Replacement: adım 11, 3 resimden 1. Canon PowerShot SX150 IS Digital Image Sensor Replacement: adım 11, 3 resimden 2. Canon PowerShot SX150 IS Digital Image Sensor Replacement: adım 11, 3 resimden 3.
      • Using the J000 Philips head screwdriver, remove the four 7mm screws from the silver panel.
      • Remove the two 5mm screws.
      • Remove the one 3 mm screw.
      • Using the same screwdriver, remove the 3mm screw from the top of the camera.
      • Pull the panel off and set it aside.
      FixBot'a Sor
      Yorum Ekle
    1. Canon PowerShot SX150 IS Digital Image Sensor Replacement, Digital Image Sensor: adım 12, 2 resimden 1. Canon PowerShot SX150 IS Digital Image Sensor Replacement, Digital Image Sensor: adım 12, 2 resimden 2.
      • Lift the two flex ribbons with your tweezers and remove them.
      • Move the circuit board to the side.
      FixBot'a Sor
      Yorum Ekle
    2. Canon PowerShot SX150 IS Digital Image Sensor Replacement: adım 13, 2 resimden 1. Canon PowerShot SX150 IS Digital Image Sensor Replacement: adım 13, 2 resimden 2.
      • Remove the three 2 mm screws from around the sensor.
      • Pull the sensor away.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 37
Her zaman: 1,457
