Ana içeriğe geç
Canon PowerShot SX160 IS Function Wheel Replacement
Neye ihtiyacın var
  1. Canon PowerShot SX160 IS Function Wheel Replacement, Function Wheel: adım 1, 3 resimden 1. Canon PowerShot SX160 IS Function Wheel Replacement, Function Wheel: adım 1, 3 resimden 2. Canon PowerShot SX160 IS Function Wheel Replacement, Function Wheel: adım 1, 3 resimden 3.
    • Unscrew the 2-4.8mm black Phillips head screws from the front of the camera using a #0 Phillips screwdriver.
    • Unscrew the 2-4.8mm black Phillips head screws from the side of the camera using a #0 Phillips screwdriver.
    • Unscrew the 3-4.8mm black Phillips head screws from the bottom of the camera using a #0 Phillips screwdriver.
  2. Canon PowerShot SX160 IS Function Wheel Replacement: adım 2, 2 resimden 1. Canon PowerShot SX160 IS Function Wheel Replacement: adım 2, 2 resimden 2.
    • Using your hands, gently separate the back panel from the camera.
    • Continue to pull the back panel until it completely detaches from the camera.
  3. Canon PowerShot SX160 IS Function Wheel Replacement: adım 3, 2 resimden 1. Canon PowerShot SX160 IS Function Wheel Replacement: adım 3, 2 resimden 2.
    • Use a #0 phillips screwdriver to unscrew the 3-3.75mm silver Phillips head screws from the function wheel panel of the camera.
  4. Canon PowerShot SX160 IS Function Wheel Replacement: adım 4, 1 resimden 1.
    • Remove and replace the function wheel.
Sonuç
Congratulations, you have successfully replaced your function wheel. To reassemble your device, follow these instructions in reverse order.
Jamie Secretan
1.962 İtibar
6 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 2-3, Panko Spring 2015 Colorado Springs, Team 2-3, Panko Spring 2015 üyesi
UCCS-PANKO-S15S2G3
3 Üyeler
Bir Yorum
Hi, I replaced the LCD screen but now my function wheel and panel don’t work. I think the ribbon got disconnected , but I can’t figure out where to attach it. Can you help?
Denise Domian - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 590
