Giriş
This guide provides a breakdown that shows how to replace the function wheel on your Canon PowerShot SX160 IS by disassembling a portion of the camera to access the function wheel.
Neye ihtiyacın var
Unscrew the 2-4.8mm black Phillips head screws from the front of the camera using a #0 Phillips screwdriver.
Unscrew the 2-4.8mm black Phillips head screws from the side of the camera using a #0 Phillips screwdriver.
Unscrew the 3-4.8mm black Phillips head screws from the bottom of the camera using a #0 Phillips screwdriver.
Congratulations, you have successfully replaced your function wheel. To reassemble your device, follow these instructions in reverse order.
1Rehber Yorum
Hi, I replaced the LCD screen but now my function wheel and panel don’t work. I think the ribbon got disconnected , but I can’t figure out where to attach it. Can you help?
