Ana içeriğe geç
Canon PowerShot SX160 IS Shutter Button Replacement
Neye ihtiyacın var
  1. Canon PowerShot SX160 IS Shutter Button Replacement, Shutter Button: adım 1, 3 resimden 1. Canon PowerShot SX160 IS Shutter Button Replacement, Shutter Button: adım 1, 3 resimden 2. Canon PowerShot SX160 IS Shutter Button Replacement, Shutter Button: adım 1, 3 resimden 3.
    • Unscrew 2-4.8mm black screws from the front of the camera using a #0 Phillips screwdriver.
    • Unscrew 2-4.8mm black screws from the side of the camera using a #0 Phillips screwdriver.
    • Unscrew 2-4.8mm black screws from the bottom of the camera using a #0 Phillips screwdriver.
    Not all of these screws are 4.8mm. There are additional screws that need to be removed as well, including a third one on the bottom, and a hidden one on the upper left after the back cover has been removed. Common sense will tell you which ones need to come out. There are also in the flash basin that need to be removed.
    Will Chamberlain - Yanıt
  2. Canon PowerShot SX160 IS Shutter Button Replacement: adım 2, 2 resimden 1. Canon PowerShot SX160 IS Shutter Button Replacement: adım 2, 2 resimden 2.
    • Using your hands, gently separate the back panel from the camera.
    • Continue to pull the back panel until it completely detaches from the camera.
  3. Canon PowerShot SX160 IS Shutter Button Replacement: adım 3, 2 resimden 1. Canon PowerShot SX160 IS Shutter Button Replacement: adım 3, 2 resimden 2.
    • Use your hands to gently separate the front panel from the camera.
    • Continue to pull the front panel until it completely detaches from the camera.
  4. Canon PowerShot SX160 IS Shutter Button Replacement: adım 4, 1 resimden 1.
    • Locate and replace the shutter button on the front panel of the camera.
Sonuç
Congratulations, you have successfully replaced your shutter button. To reassemble your device, follow these instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
Jamie Secretan
1.990 İtibar
6 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 2-3, Panko Spring 2015 Colorado Springs, Team 2-3, Panko Spring 2015 üyesi
UCCS-PANKO-S15S2G3
3 Üyeler
2Kılavuz Yorumları
Great guide on how to replace the shutter button. Where can I get the new button?
mess857 - Yanıt
did you ever figure out where to get a new button?
christinapayne1@icloud.com -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 52
Her zaman: 3,092
