Ana içeriğe geç
Canon PowerShot SX260 HS Battery Replacement
Neye ihtiyacın var
  1. Canon PowerShot SX260 HS Battery Replacement, Battery: adım 1, 1 resimden 1.
    • With the device fully assembled, hold the camera with both hands with the bottom of the camera facing toward you.
  2. Canon PowerShot SX260 HS Battery Replacement: adım 2, 2 resimden 1. Canon PowerShot SX260 HS Battery Replacement: adım 2, 2 resimden 2.
    • Place your right thumb on the sliding panel that is marked Card/Battery
    • Slide the panel to your right and you will hear a slight click. This is normal and you did not damage the device.
  3. Canon PowerShot SX260 HS Battery Replacement: adım 3, 1 resimden 1.
    • Remove your thumb from the Card/Battery panel and lift the panel 90 degrees.
    • The battery will eject slightly by the force of a spring.
    • Remove the battery and replace.
Sonuç
Tyler Kelch
622 İtibar
4 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 32
Her zaman: 1,236
