Ana içeriğe geç
Canon PowerShot SX260 HS Flash Assembly Replacement
Neye ihtiyacın var
  1. Canon PowerShot SX260 HS Flash Assembly Replacement, Flash Assembly: adım 1, 3 resimden 1. Canon PowerShot SX260 HS Flash Assembly Replacement, Flash Assembly: adım 1, 3 resimden 2. Canon PowerShot SX260 HS Flash Assembly Replacement, Flash Assembly: adım 1, 3 resimden 3.
    • Be sure to always remove the battery from the camera before disassembling to avoid permanent damage.
    • The camera has a total of 6 (3 mm) external screws that will need to be removed; 2 on the left side, 2 on the bottom, and 2 on the right side.
    • Remove the 2 screws on the left side.
    • Remove the 2 screws on the bottom of the camera.
    • Remove the 2 screws on the right side of the camera.
  2. Canon PowerShot SX260 HS Flash Assembly Replacement: adım 2, 1 resimden 1.
    • Use your plastic opening tool to gently lift and remove the back face plate.
  3. Canon PowerShot SX260 HS Flash Assembly Replacement: adım 3, 1 resimden 1.
    • After removing the exterior screws, use your fingers to gently lift off the front face plate.
  4. Canon PowerShot SX260 HS Flash Assembly Replacement: adım 4, 1 resimden 1.
    • Next, remove the 2 (3 mm) interior screws on the left side of the camera.
  5. Canon PowerShot SX260 HS Flash Assembly Replacement: adım 5, 1 resimden 1.
    • After removing the interior left screws, use a plastic opening tool to gently pull the top face plate off.
  6. Canon PowerShot SX260 HS Flash Assembly Replacement: adım 6, 1 resimden 1.
    • Next, you will need to remove the dial panel by removing the 2 (3mm) screws on the back side of the camera.
    • Gently remove the dial panel with your fingers.
  7. Canon PowerShot SX260 HS Flash Assembly Replacement: adım 7, 2 resimden 1. Canon PowerShot SX260 HS Flash Assembly Replacement: adım 7, 2 resimden 2.
    • Remove 1 (3 mm) screw from the flash generator with a Phillips screw driver
    • Gently lift the flash generator off of the camera with the plastic opening tool .
  8. Canon PowerShot SX260 HS Flash Assembly Replacement: adım 8, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Gently unplug the ribbon cable with your tweezers.
    • Be careful not to rip it.
  9. Canon PowerShot SX260 HS Flash Assembly Replacement: adım 9, 2 resimden 1. Canon PowerShot SX260 HS Flash Assembly Replacement: adım 9, 2 resimden 2.
    • Using your plastic opening tool to gently move the plug lock from the end of the ribbon cord by lifting it upward.
    • Gently remove the ribbon cable from the connector with tweezers.
  10. Canon PowerShot SX260 HS Flash Assembly Replacement: adım 10, 2 resimden 1. Canon PowerShot SX260 HS Flash Assembly Replacement: adım 10, 2 resimden 2.
    • Gently remove the ribbon cable assembly from the top of the camera with your tweezers.
    • This cable is a long piece that runs across the top of the camera.
    • The flash assembly is connected to this cable.
    • Once removed gently lift out of the camera
    • Replace the ribbon cable with the attached flash assembly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tyler Kelch
622 İtibar
4 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 22
Her zaman: 1,671
