Ana içeriğe geç
Canon PowerShot SX260 HS LCD Screen Replacement
Neye ihtiyacın var
  1. Canon PowerShot SX260 HS LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 1. Canon PowerShot SX260 HS LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 2. Canon PowerShot SX260 HS LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 3.
    • Be sure to always remove the battery from the camera before disassembling to avoid permanent damage.
    • The camera has a total of 6 (3 mm) external screws that will need to be removed; 2 on the left side, 2 on the bottom, and 2 on the right side.
    • Remove the 2 (3 mm) screws on the left side
    • Remove the 2 (3 mm) screws on the bottom of the camera.
    • Remove the 2 (3 mm) screws on the right side of the camera.
  2. Canon PowerShot SX260 HS LCD Screen Replacement: adım 2, 1 resimden 1.
    • Use your plastic opening tool to gently lift and remove back face plate.
    • Unplug the ribbon cable leading to the mode dial.
  3. Canon PowerShot SX260 HS LCD Screen Replacement: adım 3, 1 resimden 1.
    • After removing exterior screws, gently lift off the front face plate with your fingers.
  4. Canon PowerShot SX260 HS LCD Screen Replacement: adım 4, 1 resimden 1.
    • Remove the 4 (3 mm) screws that are under the face plate.
  5. Canon PowerShot SX260 HS LCD Screen Replacement: adım 5, 1 resimden 1.
    • Next, remove the 2 (3 mm) interior screws on the left side of the camera.
  6. Canon PowerShot SX260 HS LCD Screen Replacement: adım 6, 1 resimden 1.
    • After removing the interior left screws, use a plastic opening tool to gently pull the top face plate off.
  7. Canon PowerShot SX260 HS LCD Screen Replacement: adım 7, 1 resimden 1.
    • Next,take off the 2 (3mm) screws on the back side of the camera to remove the dial panel.
    • Gently lift the panel with your fingers.
    • Be careful not to rip the attached yellow ribbon cable.
  8. Canon PowerShot SX260 HS LCD Screen Replacement: adım 8, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Carefully unplug the yellow ribbon cable from the front of the camera using your tweezers.
  9. Canon PowerShot SX260 HS LCD Screen Replacement: adım 9, 1 resimden 1.
    • Gently slide the LCD screen to the right and remove.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Tyler Kelch
622 İtibar
4 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 28
Her zaman: 4,316
