Ana içeriğe geç
Canon PowerShot SX260 HS Motherboard Replacement
Neye ihtiyacın var
  1. Canon PowerShot SX260 HS Motherboard Replacement, Motherboard: adım 1, 3 resimden 1. Canon PowerShot SX260 HS Motherboard Replacement, Motherboard: adım 1, 3 resimden 2. Canon PowerShot SX260 HS Motherboard Replacement, Motherboard: adım 1, 3 resimden 3.
    • *Be sure to always remove the battery from the camera before disassembling to avoid permanent damage.
    • There are a total of 6 (3mm) external screws that will need to be removed; 2 on the left side, 2 on the bottom, and 2 on the right side.
    • 1.) Remove the 2 screws on the left side
    • 2.) Remove the 2 screws on the bottom of the camera.
    • 3.) Remove the 2 screws on the right side of the camera.
  2. Canon PowerShot SX260 HS Motherboard Replacement: adım 2, 1 resimden 1.
    • Use spludger tool or small flathead screw driver to gently lift and remove back face plate.
  3. Canon PowerShot SX260 HS Motherboard Replacement: adım 3, 1 resimden 1.
    • After removing exterior screws, gently lift off the front face plate.
  4. Canon PowerShot SX260 HS Motherboard Replacement: adım 4, 1 resimden 1.
    • After removing the front faceplate you will find 4 (3mm) screws on the interior.
    • Remove all 4 interior screws.
  5. Canon PowerShot SX260 HS Motherboard Replacement: adım 5, 1 resimden 1.
    • Remove 1 (6 mm) Screw from the bottom of the silver metal plate. The screw is also silver
  6. Canon PowerShot SX260 HS Motherboard Replacement: adım 6, 1 resimden 1.
    • With blue spludger tool gently lift the metal plate from the face of the camera.
    • The plate is held by a piece of double sided tape so there will be a bit of resistance.
  7. Canon PowerShot SX260 HS Motherboard Replacement: adım 7, 1 resimden 1.
    • Remove 3 (3 mm) screws from the top surface of the motherboard.
    • You will notice that there is one on the top, and 2 on the bottom in a triangular shape.
  8. Canon PowerShot SX260 HS Motherboard Replacement: adım 8, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Gently remove the ribbon cable from the top of the motherboard with a pair of tweezers.
    • Be careful during this step not to rip or tear the cable.
  9. Canon PowerShot SX260 HS Motherboard Replacement: adım 9, 1 resimden 1.
    • Use the blue spludger tool to gently unplug the last ribbon cable that is attached to the motherboard.
  10. Canon PowerShot SX260 HS Motherboard Replacement: adım 10, 2 resimden 1. Canon PowerShot SX260 HS Motherboard Replacement: adım 10, 2 resimden 2.
    • Remove the motherboard with your fingers.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Tyler Kelch
622 İtibar
4 adet Kılavuz yazıldı
Ekip
2 Yorum
Where is the internal clock/calendar battery located?
GPa Rocks - Yanıt
Internal clock battery is under circuit board on right side of lens as seen in photo for Step 9. See 2:48 - 3:19 in this video: https://www.youtube.com/watch?v=Awmm6hDm....
Paul Unger - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 32
Her zaman: 2,127
