Ana içeriğe geç
Canon PowerShot SX280 HS AF Assist Lamp Replacement
Neye ihtiyacın var
  1. Canon PowerShot SX280 HS AF Assist Lamp Replacement, AF Assist Lamp: adım 1, 1 resimden 1.
    • Remove the outer covering from the camera.
    • Remove the tabs from the motherboard.
  2. Canon PowerShot SX280 HS AF Assist Lamp Replacement: adım 2, 1 resimden 1.
    • Remove the screws on top of the camera.
  3. Canon PowerShot SX280 HS AF Assist Lamp Replacement: adım 3, 1 resimden 1.
    • Remove the tabs which will slide out with a chip. The chip is attached to the GPS.
  4. Canon PowerShot SX280 HS AF Assist Lamp Replacement: adım 4, 1 resimden 1.
    • Remove the wifi chip.
    • Remove the screw.
  5. Canon PowerShot SX280 HS AF Assist Lamp Replacement: adım 5, 1 resimden 1.
    • Remove all the screws around the lamp. This releases the lamp.
Sonuç
Osmand A Munoz
228 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-5, Miles Spring 2015 UMass Dartmouth, Team 1-5, Miles Spring 2015 üyesi
UMASSD-MILES-S15S1G5
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 495
